Insignia NS-42P650A11 - click, click, off - shorted IGBT
  • ngth82
    • Jul 2015
    • 541
    Good afternoon all -
    I picked up an Insignia NS-42P650A11 (MFG April 2011).
    I have a feeling everyone is going to tell me to either: junk it, or buy a new Y-sus, Y-buffer and X-sus boards to do a complete swap (which is a bad return on investment in my case)
    This is what I know:
    • Main: BN96-14887A V1000.3
    • T-Con: PBA: LJ92-01708A, PCB: LJ41-08392A
    • Power board: BN44-00329A, 42" PSPF301501A
    • Y-sus: 42U2P_Y-MAIN
    • Y-buff: 42U2P_YB, PBA # LJ92-01739A, PCB # LJ41-08594A
    • X-sus: 42U2P_XM(1 layer),
    • Panel: Samsung S42AX-YD13
    • The Y-sus makes a popping noise (note, not clicking) - a popping noise - when you plugin the unit. I see that the high voltage 330pF 1kV cap at location C5008 has destroyed itself.
    • I replaced the high voltage cap with an equivalent part. This did not fix the TV.
    • I disconnected all of the boards. The main power supply board correctly generates Vs (211V) and Va (54V). The power supply board goes into protection mode since the X/Y boards are not hooked up. I do see the Vs and Va rails ramp momentarily to their target voltages. So, that appears to be okay.
    • If I ONLY add the Y-sus board, the TV tries to turn on twice (?), but then shuts down again.
    • If I add the X-sus board to this, the TV tries to turn on twice (?), but then shuts down again. (same behavior as with Y-sus only)
    • I tested the Y-buffer for shorts - no short that i can find through each of the ICs.
    • I'm not hooking up the Y-buffer to the equation since the X-sus and Y-sus are suspect.
    • I see that the X-sus has two IGBTs that are dead short (they are marked XG - Q4007, and XS - Q4001).
    Is it even worth swapping out the IGBTs on the X-sus board?
    Should the TV stay on if I have the Y-buffer and X-sus disconnected?
    Thanks!
    -Thomas
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
  • ivtec
    • Dec 2008
    • 1967
    Re: Insignia NS-42P650A11 - click, click, off - shorted IGBT
    Thanks!
    -Thomas
    i just trashed a 32'' of that model bad panel,hope it's not your case good luck
    • ngth82
      • Jul 2015
      • 541
      Thanks.
      If i can find out why the Y-sus causes the unit to click, then maybe it would be worthwhile attempting to replace the IGBTs on the X-sus.
      As it stands right now, a $5 initial gamble to get the unit isn't worth the money that needs to be dumped in to get a complete set of sus + buffer boards.
      -Thomas
      • ngth82
        • Jul 2015
        • 541
        Just following up with this thread.
        I ended up taking the X and Y boards apart.
        The Y-sus has a dead short between all of the IGBT pins at locations Q5003, Q5007 and Q5008. (MPN markings say "RJP30E2" - 360V, 35A, N-Channel IGBT). I removed the heatsink and unsoldered the parts. They tested bad as it still showed a dead short between the parts. The board pads show an open loop, thus confirming it was these three parts.
        I did the same thing for the X-sus - i found a dead short on the two IGBTs labeled Q4007 and Q4001. (MPN markings say "RJH30E2" - 360V, 30A IGBT).
        I purchased replacement parts this evening from eBay - qty 5 each (with a few to spare) - $9 in parts.
        -Thomas
        • ngth82
          • Jul 2015
          • 541
          Hi all -
          I received the replacement IGBTs today. I installed them and checked for shorts - none found.
          I installed the y board, and connected the power from the main power board. Vs and Va ramp up then shutdown since the other boards are not installed. I then plugged in the x board as well. The power boards are up - vs and va are stable (210v and 54v per the panel sticker).
          I turned it off and waited until the caps discharged then connected the y buffer board. I turned it back on and the power rails still appear to be good. I shut it off again, waited, then connected the ribbon cables from the PDP to the power boards. I made sure the LVDS cable was disconnected and forced the panel into the test mode by jumpering across Pins 3&4 on the T-CON.
          but instead of getting a happy test pattern, I get what is shown in the attached image. What is the likelihood this is a buffer board problem? Or is it the panel?
          -Thomas
          • mikkele86
            Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
            by mikkele86
            hello.
            I have two power amplifiers, both having their IGBT blown on the PSU.
            The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
            I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
            I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
            So I though i missed a capacitor or diode. I removed...
            01-06-2024, 06:45 AM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
          • cajoeg
            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
            by cajoeg
            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
            02-10-2025, 04:01 PM
          • Truncatedhose
            Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
            by Truncatedhose
            Greetings all!
            Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
            Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
            07-04-2018, 10:59 AM
          • zwarder
            eax61319402 50PJ350 YSUS
            by zwarder
            Hi
            Had shorted YSUS
            Q24 RPJ63F3
            C726 cap
            Q11 K3667
            R528 & R529 2.2 ohm
            replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
            ZSUS is also good as far as I can tell
            Anyone could help me out on this one
            10-23-2023, 08:11 AM
