LG 50PS30 Image Problem
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 50PS30 Image Problem
    Nice find!
      Nice! Out of interest, what does the waveform look like now? Goes to show how useful a scope is for plasma repair!
      • mmartell
        • Oct 2013
        • 3189
        Sorry tom had this sitting out where it shouldn't have been so when I got it repaired I zipped it up and made the wife happy again. At least temporarily
        • mmartell
          • Oct 2013
          • 3189
          File this one under "NOT SO FAST !". The resistor has gone troppo again, or on it's way anyhow currently measuring in the mega ohms...
          Would it be fair to suggest there is too much current flowing through the resistor ? I have no idea how this circuit works or should work. I'll post a shot of that portion of the board, maybe someone has some ideas where I should be looking.
          • mmartell
            • Oct 2013
            • 3189
            There is a pair of diodes tied to the resistor, will have a look at them first.
            • mmartell
              • Oct 2013
              • 3189
              Here's a shot of the area in question. Now I'm as good as colour blind so my wife tells me the resistor is vvgg and my daughter tells me it could be rrgg. Only one can be right, which do you think it is ?
              If it is rrgg then it's 2.2ohm instead of 7.7ohm. Would putting an 11ohm resistor in place of a 2.2 ohm one be sure to cause it to go open ?
              And the two parallel diodes to the left of the resistor test about 0.3v forward and open in reverse.
              • freakaftr8
                • Oct 2012
                • 3743
                Thats rrgg, 2.2 ohm. Could be the reason, also I thing those are high wattage. what wattage did you use? I think the original is a 2 watt
                  Yeah, definitely red-red-gold-gold. 7.7 ohm (violet-violet-gold-gold) would be a very unusual value. It needs to be the right value. A big resistor like that is dissipating quite some power. An incorrect value will increase power dissipation by 5x.
                  What you can try doing is measuring the voltage across the resistor but you must use a good multimeter as a cheap one will pick up switching noises from the Y-sustain board. If you measure more than a volt or two, then there's a fault somewhere drawing much more current than it should.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Ya I freak I had replaced it with the same 2 w rated resistor, just a different value thanks to my wife seeing violet over red - thanks for clearing up the value.
                    I had a look around the board again and touched up the top-side joints on two mosfets in the vicinity that looked iffy. Then because I hadn't yet read the latest posts here I bodged in a 10 ohm 5 watt resistor ! Running good again but will recheck the value to make sure even that one is not increasing.
                    Is there a problem running a higher wattage resistor, I mean is it meant to act as a fuse should something go wrong ?
                    Also, does that resistor set the base range for the set_up trim pot, meaning if I can still dial in a good pic would it be ok to leave it ?
                    Will read the voltage across it, tom, later this afternoon.
                      The resistor is probably important to set up some part of the set up circuit. An increased value is likely to cause excess power dissipation and the resistor will eventually fail as a result.
                      • mmartell
                        • Oct 2013
                        • 3189
                        0.288v across the resistor.
                        I ran it last night and this morning with an empty analog channel (snow) and everything appeared good. The set auto shuts off under "no input" condition but I just tried again with antenna and regular program content. As I was typing this response the resistor went from mildly warm to hot so I'll be swapping it for the correct value.
                        I guess you think the voltage across the resistor is ok but shouldn't I be concerned with current THROUGH it ?
                          V=IR (ohms law)
                          So, I=V/R
                          (I=current, V=voltage, R=resistance)
                          This means that the voltage can be used to work out the current. The figures you have provided indicate 28mA which seems quite reasonable.
                          I would make sure to install a 2.2 ohm resistor in the place of the 10 ohm one. The resistor is probably used to reduce the dissipation in the transistor and may shape the set up wave slightly.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Excellent. (I knew ohm's law would be useful here but my theory is lacking...)
                            I've already harvested another resistor of the same rating and wattage. Will install tonight and update.
                            Wouldn't it be odd for just the resistor to fail ?
                              I have seen power resistors fail normally without obvious cause, and given the set otherwise works I'm not really surprised you can't find anything else that's bad.
                              While you're fiddling check the waveform again, would be good to see if it's looking normal or if something else is wrong.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Changed to a 2.2 ohm resistor, the voltage across it has gone down to 0.067v and I guess that means the current across it is unchanged.
                                Will get the scope on it and get a pic up.
                                  The current is 30.5mA, which is slightly higher, as expected.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    The resistor value is holding steady and the picture is still looking good. Here are the scope images I just took using the same scope values. I don't see any changes. Am I not capturing the wave properly ?
                                      You probably want to capture the end of the sustain pulse here, as this is a reset pulse...the other one may be something different, different plasma panels have different drive primitives.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Well the set has been zipped up again but there does seem to be a difference between the wave you indicate and the earlier one I posted before the repair. Not much in the way of resolution but they do look different. For future reference, which part of the wave is the set_up ?
                                          The ramp from 0V to Vs, or 0V to a higher voltage than Vs on older sets (often called Vset or Vsetup, around 300-400V) is the set-up ramp.
                                          Plasma TVs past 2008-2009 or so use reduced-voltage Vset, keeping it below or equal to Vs reduces the cost of the Y-sustain driver circuit.
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                          • vabea
                                            Asus X550LD Image problem
                                            by vabea
                                            Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
                                            Thanks...
                                            04-07-2025, 08:33 AM
                                          • Track4207
                                            Hisense H50N5300UK reboots when showing full red images
                                            by Track4207
                                            Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                                            What happens:
                                            • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                                            • The problem image is displayed very briefly, then the
                                            08-30-2023, 11:58 AM
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            Yesterday, 11:38 AM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
