LG 50PS30 Image Problem
  • mmartell
    • Oct 2013
    • 3189
    All voltages are in spec however the image is not right. There is a rainbow defect visible and also a splotchy blackness that goes away quickly after cold start.
    I think this set is a sibling of the 50ps3000 which is known for cracked joints under the sus coils. I had both y and z sus's out and they look real clean and the joints look good.
    The internal test patterns also look much better than program material but I'm not convinced yet that it just isn't performing better in the patterns.
    I have a scope and can check waveforms but don't know where the test points are.
    Ysus EBR55360701
    Zsus EBR55360601
    Any suggestions ?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 50PS30 Image Problem
    I believe vscan test point is on lower buffer. Is that in spec too? Try heating y board up a bit with a hair dryer and see is problem persists. Looks like low VS or Vscan to me.
    Sometimes I try turning up VS about 10 to 15v tok alleviate symptoms of an old panel.
    • mmartell
      • Oct 2013
      • 3189
      Vsc as in pic ? In spec as defined by the panel, 140v.
      I think I may have boosted Vs but I'd doubt I went that high for fear of blowing something up lol but since it's possible I will revisit.
      • mmartell
        • Oct 2013
        • 3189
        I turned up Vs but the set just shut down at about 208v with not change in the pic. I backed off the pot to something below the proper setting and when I restarted the pic was immaculate. I watched it for about thirty seconds then it suddenly switched back to rainbows.
        Either a dry joint somewhere, a failing piece of silicon or an intermittent cable connection I guess.
        Going to start by reseating all the cabling as that's the simplest.
        • freakaftr8
          • Oct 2012
          • 3743
          Ok either a voltage dropped or problems within the Y board. Yes vscan + on that end of resistor with red lead of dmm Chassis ground with neg lead. What do you get?
          • mmartell
            • Oct 2013
            • 3189
            I measured across the resistor as indicated on the silkscreen. I get 140v, matching panel sticker.
            • freakaftr8
              • Oct 2012
              • 3743
              Try heating up logic board a little.
              • chrismurphy
                • May 2014
                • 251
                • australia
                look for bad solder joints on Zsus board and make sure the Ysus screws are tight
                • mmartell
                  • Oct 2013
                  • 3189
                  All screws are tight and I did try heat on various boards. Will try again.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Can anyone point out where to attach a scope for the y and z sus boards ?
                    • mmartell
                      • Oct 2013
                      • 3189
                      delete... was wondering if anyone had the SM as elektrotanya didn't have it... but google did
                      • mmartell
                        • Oct 2013
                        • 3189
                        Here's a screenie of my zsus wave. I used the "Auto" function to zone in on the wave. I'm only seeing about 155v p/p but according to the sm I should be seeing about 100v more than that. Am I doing something wrong with the scope or have I found a problem ?
                        • mmartell
                          • Oct 2013
                          • 3189
                          Here's a shot of the ysus. Does this look as it should ?
                          • mmartell
                            • Oct 2013
                            • 3189
                            Any help with these waveforms ?
                            • mmartell
                              • Oct 2013
                              • 3189
                              Looking at this again... tried adjusting Set_up and Set_down. Set up has a noticeable impact on picture quality but Set up has zero impact.
                              Shouldn't I be seeing a change in screen quality when adjusting this pot ?
                                not always, set down can sometimes do nothing, depends how close the panel is to the limits, you'll probably notice some difference on fine gradients where more maldischarge is visible. or on lower Vs or combinations with set up that causes maldischarge.
                                Your Y and Z waveforms look normal, what's important for the Z is having the Z-bias voltage period (~100V) in between the sustain periods (200Vp-p). Which you seem to have. For the Y, you should have a nominal -190V base for the waveform, with ramps back to zero, and sustain portions from 0V to 200V. That being said, your set up period looks absent or too short, so there could be a fault there. Missing or rapid set up will cause overdiffusion, where pixels maldischarge all over the panel.
                                You need to rule out a control board issue by checking the test patterns are ok.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  The test patterns "look" normal. I say that because I have this feeling they're misleading due to the nature of test content vs regular program material. I know that normally this would not be an issue - maybe I'm fooling myself.
                                  If the patterns are ok I guess I have a mainboard problem.
                                  I think what I'll do is hook up the scope again to the ysus and adjust the pot and see if the waveform is changing.
                                  Thanks for confirming the Z looks good.
                                    It's probably not a main board issue. But you could see what the gradient test pattern looks like when using EXT AUTO GEN.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      That would be my last guess too but...
                                      The gradient patterns are black and white and look good. May be a colour issue(?!) I just remembered I was going to force the pic black and white (or find some old material) and see how the pic looks.
                                      It's a peculiar problem, at least to me.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        BINGO.
                                        Had some time to look at this again and found an open 7.7ohm power resistor near the setup pot. Replaced it with a 10 ohm resistor (didn't have the same resistor so thought better to go bigger instead of smaller) and set has been working normally for the last few hours.
                                        Thanks for the help guys.
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • vabea
                                          Asus X550LD Image problem
                                          by vabea
                                          Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
                                          Thanks...
                                          04-07-2025, 08:33 AM
                                        • Track4207
                                          Hisense H50N5300UK reboots when showing full red images
                                          by Track4207
                                          Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                                          What happens:
                                          • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                                          • The problem image is displayed very briefly, then the
                                          08-30-2023, 11:58 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
