Rca_led65g55r120q
  • dazdncnfusd
    • Sep 2017
    Rca_led65g55r120q
    Hello all.
    First meaningful post. As the subject states, I have an RCA 65" LED TV. I got it a couple years ago after a deployment. Not too long after I got it, the one dead pixel spread to a line across the screen. RCA warranted it, and refunded my entire purchase price, but did not make me return the cord. As it was still 99% functional, I continued to use it until a couple of months ago when the screen went out. I took a quick video with my phone, which I'll link below.
    I'm honestly brand new to TV component repair, so hopefully, one of you fin folks can help me sort out what broke, and how to fix it.
    https://www.youtube.com/watch?v=WsLH...ature=youtu.be
    Thanks!
    Later!
  • Hy4woj
    • Oct 2017
    • 41
    Re: Rca_led65g55r120q
    I take it you have sound but no picture? it looks like the screen flashes for a split second then shuts down? If this is the case more than likely you have a blown LED (s) inside the panel. I have two of these sets that I purchased within the last month for dirt cheap. Both had blown LED(s) and I replaced the individual LED(s), both sets are up and running. Dim the lights in your room, turn on the set and shine a flash light on the screen. I bet you will see a faint picture. These sets are notorious for LED failures.
    • dazdncnfusd
      • Sep 2017
      Yeah. In the brief flashes, the screen is functioning, but then it flashes off. I wasn't sure if that indicated a power or main board, or led's. I assume there is info on how to troubleshoot and repair the led strips, so I'll see if I can sort that out.
      Thanks!!!!
      • Hy4woj
        • Oct 2017
        • 41
        wow, sorry for the late reply! I don't know if you are still working on the set or not but this may help someone else. There are youtube videos that walk you through troubleshooting LED backlights.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
