Sharp LC-70C8570U
  • nelson6861
    • Jul 2016
    • 67
    Re: Sharp LC-70C8570U
    In post #14
    I have 3 regulators reading 0v
    Could this be a problem also...
    • nelson6861
      • Jul 2016
      • 67
      Also i want to add PW1 and PW2 comes from t-con board
      And they read .7v PW1 and 0 PW2
      • freakaftr8
        • Oct 2012
        • 3743
        And I'm assuming you tried powering up with all 4 pulled as Well? If so, steady power light but no backlights?
        • budwich
          • Jul 2015
          • 3097
          Since you are "playing" with the set, why don't you try the "standard... disconnect the corner cable test" with the tcon to panel cables all connected to see what happens. Also try it from the other corner. You have nothing to loose and it might help with the "diagnosis"... maybe.
          • nelson6861
            • Jul 2016
            • 67
            Yess. I connected all four ribbon cables also and same 2/5 blink code
            • nelson6861
              • Jul 2016
              • 67
              Ok...
              But the t con board is missing pw1 and pw2 volts to power supply...
              I will try it
              • nelson6861
                • Jul 2016
                • 67
                Originally posted by nelson6861
                Ok...
                I will try it
                Can you explain what that will do...
                Pulling those ribbon cables
                • budwich
                  • Jul 2015
                  • 3097
                  probably nothing but I am having a hard time following what you have done and when. A number of these type of sets have panel issues which "manifest" themselves as 2-5 type problems because of their impact on powering and the limited "code design for errors". Further, depending on the failure, the system shuts down powering accordingly (sometimes fast). Anyways, unless you have something better, it was just a suggestion. I know when I was "playing" with my 70in, it took quite a bit of "playing" before I got anywhere as a comments of "panel problem" was "popular". :-)
                  Plus... I don't understand "the pw1,pw2 to power supply... come from the tcon to the power supply...." when are you reading / monitoring these? at power up, once code flashing occurs, before code flashing occurs????? Again, reading back your "steps"... sometimes you have 12v and then other times you have 0v.... this tells me that the "process" isn't quite set for consistency. But again just my "eyes" from the internet.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    OK judging that you see 83 volts at each output to the LED drivers And 12 votes going to the tcon tells me that the power filter correction circuit of the power supply has to be going high. Interesting fact that you mention you're getting 83 v to LED drivers. If they were disconnected out of circuit the backlight controller does not allow power to backlights. (Or an open backlight output channel for that reason as well)
                    And without an actual service manual I would not be open to tell if 83 volts to each channel output is optimal for the backlights to light up. To me that sounds a bit low.
                    However if you can connect one side of the panel to the point were you do not see the error Flash in the power light stays consistent Look into the screen with a flashlight and see if it has an image without the backlights being lit
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Also I might add that if the panel had indeed failed, Removing the short by disconnecting the shorted side of the LCD panel via the to right or left ribbons, The tcon May already be damaged to the point where it does not allow power supply spool up of led's, When you notice that the 2-5 error goes away by disconnecting the offending side, If you do not have a picture with the flashlight test You could check the inductors on the tcon to see if you're getting other voltages besides just 12 V with the power light on solid.
                      • nelson6861
                        • Jul 2016
                        • 67
                        The pw1 and pw2 were reading off the power supply
                        • nelson6861
                          • Jul 2016
                          • 67
                          Sorry pwm1 and pwm2 from tcon board to powersupply
                          • budwich
                            • Jul 2015
                            • 3097
                            1st of all how did you test the backlights did you remove the LCD panel in physically power the backlights with a dmm?
                            If you look on this forum you will see many postings about faults with sharp LCD TV's especially the 70 Inch panel. When you 1st power the TV do you get a solid light light before the 2 - 5 Flash? Do you see any indication of the back lights coming on even briefly before shutdown? Also we would watch your monitor voltage to the tcon. you should be getting 12 v to the connector
                            op... I don't think you "addressed" / answered all of these questions.
                            Also, what's the history of the set?
                            Lastly, can you post a picture of the "whole back" so we can see the layout / cabling.
                            • budwich
                              • Jul 2015
                              • 3097
                              well unless you were looking with a scope, I don't think your meter will show you much for these.
                              • nelson6861
                                • Jul 2016
                                • 67
                                Here are those pictures.
                                Can you see the heat trail on the tcon board. There is a thermal pad on the bottom probably should have been one on the top too
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  ok... but again, what is the history of the set? and again, you didn't address the questions that freakaftr8 posted earlier.
                                  potentially, it appears that there is "something" that has happened on the tcon but I wouldn't necessarily say "heating"... more like "moisture marks".
                                  • nelson6861
                                    • Jul 2016
                                    • 67
                                    I dont know history of tv..
                                    I just know it does not work when i got it from a friend.
                                    I plugged it in and 2/5 fault code. I know this does not help. I have a new t con board coming in tomorrow but i dont think thats goin to help my panel issue. I appreciate your help
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      OK. no problem with "unknown history"... that is better than "I won't answer". Again, you still have not answered the questions freakaftr8 asked that I also asked you to clarify.
                                      Hopefully, your replacement tcon will get you there but at this point, I wouldn't necessarily hold my breath.
                                      • nelson6861
                                        • Jul 2016
                                        • 67
                                        What was the post # where freak8 asked the question
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          look at my post 33... anyways best of luck with your card replacement.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                          • joblo37pam
                                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                            by joblo37pam
                                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                            10-26-2023, 02:17 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • freakaftr8
                                            Asus a15 FA507RE-A15.R73050T failure
                                            by freakaftr8
                                            So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
                                            03-28-2024, 10:58 PM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
