Sony chassis AE-5 led blinks 4 times
  • fpsousa
    • Dec 2015
    • 29
    • Portugal
    I have a Sony KV-29FX60E (chassis AE-5) that blinks 4 times; the manual tells that is vertical protect. I´ve already change IC vertical STV9379 but no change. Whath could be?
    Tanks
  • R_J
    • Jun 2012
    • 9625
    Re: Sony chassis AE-5 led blinks 4 times
    There are a couple resistors near the flyback, R6834 and R6835 (.47 ohm) They supply the + & - 15 volts for the vert. output ic
    • fpsousa
      • Dec 2015
      • 29
      • Portugal
      They are good, but these two voltages don´t up enough, because the TSL seems to be up briefly and goes off imediatly. if no horizontal, no voltage to vertical circuit.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Check the Horiz Driver Transistor Q601. That could be faulty also. See if this SM I uploaded would help you.
        • freakaftr8
          • Oct 2012
          • 3743
          Does this set use that horrible jungle IC Like the WEGA sets did is the early to mid 2000s?
          • R_J
            • Jun 2012
            • 9625
            Andrew, thats a Sharp manual, this is a Sony, go to https://elektrotanya.com for the manual SONY KV-29FX60A B D E U CHASSIS AE5
            Check the B+ voltage to the horz. outputs, is it +135 and not over.
            Try disconnecting CN5600 to the "C" board (crt board) if one or more of the video drive ic's are bad (shorted +200v)they will shut down the horz. circuit.
            I would also check the 2 pin amp transistors, Q6805 & Q6806
            I have only worked on the North American versions of the Sony crt's.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              OOPS!!! Hope I didn't confuse things...Thanks for pointing out my mistake, R_J...
              • fpsousa
                • Dec 2015
                • 29
                • Portugal
                I send a diagram AE-5; the CXA2100Q generate HDrive at near 32Khz (double of the portuguese standard -16325 Khz), but don´t generate the vertical SAW at pins5 and 6 but the other pins, generate normal vertical signals, 500Khz oscilator good, even put the Vprotect at pin 16 to a 0 volts; so, only the pins 5 and 6 (SAW+ and SAW-), don´t out nothing; could be these IC? or another protection is active?
                Tanks
                • R_J
                  • Jun 2012
                  • 9625
                  I believe the saw waveforms are generated by a working vertical output, not by the cxa2100q ic. I also believe the 4 blink could be misleading, If you don't have the flyback working, you won't develope the +15 & -15 volts for the vertical output ic to function, with no vertical output waveform the tv thinks the vertical has failed but a fault in the flyback circuit may also show this error, It could be a bad ihvt (flyback)
                  Do you have the horz. drive to the horz. output transistors? do you have any high voltage at all?
                  • fpsousa
                    • Dec 2015
                    • 29
                    • Portugal
                    Regard: pins 5 and 6 go to A4 and A5 CN 4101 that goes to A board CN 1401 A4 and A5 (DE8 and DE10) to D board pins 17 and 19 and finaly, signal enters by CN6102 same pins and go to pin 1 and 7 IC 6700, they are enters, do you agreed?
                    Yes, i´ve already had another Sony that 4 blinks, are TSL.
                    I´ve tested E board out the tv set and aplly 9 V and the result is a good HDrive (about 32 Khz square wave) and some Vertical outs on pins 3,4, and good 503Khz on 15.
                    So, my doubt at these time is if the CXA2100 are really good or some protecion is on because when put E board on TV the HD not go out too.
                    • fpsousa
                      • Dec 2015
                      • 29
                      • Portugal
                      Sucess! i´ve already discover the problem: the xray protection was activeted and don´t allows power on. No problem with vertical circuits. After this problem had been sorted out, the tv works good.
                      Thank you all for the help.
                      • Nairolf
                        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                        by Nairolf
                        I have a Samsung DM32D display.
                        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                        Here’s what I have tried so far:
                        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                        From these tests, I suspect the problem might be on the mainboard. Could anyone...
                        08-24-2025, 03:47 AM
                      • mopenstein
                        Looking for Vertical IC for RCA Chassis CTC159L CRT
                        by mopenstein
                        I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                        Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                        I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                        09-24-2023, 10:41 AM
                      • jason123
                        Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                        by jason123
                        Hi there,
                        I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                        So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                        I see 2 posts that are relevant:
                        https://www.badcaps.net/forum/troubl...j-oled-5-blink
                        https://www.badcaps.net/forum/troubl...g-hardware-dev...
                        10-29-2025, 02:01 PM
                      • matwan
                        Sony XR-55X90J 5 blinks
                        by matwan
                        I have problem with SONY 55X90J. After several check status is as below;
                        1. Running power board as stand alone:
                        TCON_12V =~ 12.6V
                        EVDD V On Max 24V= 19V.
                        2.
                        Running power board with TCON as stand alone:
                        Effect as below, attched.
                        3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                        "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                        Best regards....
                        09-28-2025, 04:26 AM
                      • GoodCapDude
                        Sony XBR-75X940E intermittent 6 blinks error code
                        by GoodCapDude
                        Hi everyone. First post on Badcaps!
                        I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                        09-20-2025, 06:07 AM
