Sony chassis AE-5 led blinks 4 times
  • fpsousa
    • Dec 2015
    • 29
    • Portugal
    I have a Sony KV-29FX60E (chassis AE-5) that blinks 4 times; the manual tells that is vertical protect. I´ve already change IC vertical STV9379 but no change. Whath could be?
    Tanks
  • R_J
    • 9546
    Re: Sony chassis AE-5 led blinks 4 times
    There are a couple resistors near the flyback, R6834 and R6835 (.47 ohm) They supply the + & - 15 volts for the vert. output ic
    • fpsousa
      • Dec 2015
      • 29
      • Portugal
      They are good, but these two voltages don´t up enough, because the TSL seems to be up briefly and goes off imediatly. if no horizontal, no voltage to vertical circuit.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Check the Horiz Driver Transistor Q601. That could be faulty also. See if this SM I uploaded would help you.
        • freakaftr8
          • Oct 2012
          • 3743
          Does this set use that horrible jungle IC Like the WEGA sets did is the early to mid 2000s?
          • R_J
            • 9546
            Andrew, thats a Sharp manual, this is a Sony, go to https://elektrotanya.com for the manual SONY KV-29FX60A B D E U CHASSIS AE5
            Check the B+ voltage to the horz. outputs, is it +135 and not over.
            Try disconnecting CN5600 to the "C" board (crt board) if one or more of the video drive ic's are bad (shorted +200v)they will shut down the horz. circuit.
            I would also check the 2 pin amp transistors, Q6805 & Q6806
            I have only worked on the North American versions of the Sony crt's.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              OOPS!!! Hope I didn't confuse things...Thanks for pointing out my mistake, R_J...
              • fpsousa
                • Dec 2015
                • 29
                • Portugal
                I send a diagram AE-5; the CXA2100Q generate HDrive at near 32Khz (double of the portuguese standard -16325 Khz), but don´t generate the vertical SAW at pins5 and 6 but the other pins, generate normal vertical signals, 500Khz oscilator good, even put the Vprotect at pin 16 to a 0 volts; so, only the pins 5 and 6 (SAW+ and SAW-), don´t out nothing; could be these IC? or another protection is active?
                Tanks
                • R_J
                  • 9546
                  I believe the saw waveforms are generated by a working vertical output, not by the cxa2100q ic. I also believe the 4 blink could be misleading, If you don't have the flyback working, you won't develope the +15 & -15 volts for the vertical output ic to function, with no vertical output waveform the tv thinks the vertical has failed but a fault in the flyback circuit may also show this error, It could be a bad ihvt (flyback)
                  Do you have the horz. drive to the horz. output transistors? do you have any high voltage at all?
                  • fpsousa
                    • Dec 2015
                    • 29
                    • Portugal
                    Regard: pins 5 and 6 go to A4 and A5 CN 4101 that goes to A board CN 1401 A4 and A5 (DE8 and DE10) to D board pins 17 and 19 and finaly, signal enters by CN6102 same pins and go to pin 1 and 7 IC 6700, they are enters, do you agreed?
                    Yes, i´ve already had another Sony that 4 blinks, are TSL.
                    I´ve tested E board out the tv set and aplly 9 V and the result is a good HDrive (about 32 Khz square wave) and some Vertical outs on pins 3,4, and good 503Khz on 15.
                    So, my doubt at these time is if the CXA2100 are really good or some protecion is on because when put E board on TV the HD not go out too.
                    • fpsousa
                      • Dec 2015
                      • 29
                      • Portugal
                      Sucess! i´ve already discover the problem: the xray protection was activeted and don´t allows power on. No problem with vertical circuits. After this problem had been sorted out, the tv works good.
                      Thank you all for the help.
                      • mopenstein
                        Looking for Vertical IC for RCA Chassis CTC159L CRT
                        by mopenstein
                        I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                        Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                        I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                        09-24-2023, 10:41 AM
                      • gpo23
                        Sony KDL-40V3000 - Vertical lines
                        by gpo23
                        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                        With the new t-con the color are good but there are vertical lines on all the screen :
                        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                        Is there a way to fix the vertical lines on the new t-con ?
                        Thank you for your help
                        gpo23...
                        10-04-2023, 09:11 AM
                      • AK_777
                        Sony KD-65A1 Repair – 4 Red Blinks Error
                        by AK_777
                        Hi everyone!
                        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                        02-20-2025, 04:15 PM
                      • jchon
                        Sony A1e 5-blinks help
                        by jchon
                        Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                        I found the service manual, which was critical to know where to probe.
                        https://www.manualslib.com/manual/20...1e-Series.html
                        With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                        Unfortunately the 5-blinks...
                        06-28-2023, 11:52 AM
                      • heol
                        Sony KDL-49WE663 red led blinks 6 times
                        by heol
                        Hi.
                        I'm working on a Sony KDL-49WE663 and when I first turned it on it was blinking red 6 times.
                        I opened the TV and saw an inductor was fallen off the power/LED driver board so I soldered it back on and tested again, TV turns on and seems fine but the inductor heats up really fast and fell off again.
                        Then tested the backlight LEDs they all seem fine with LED backlight tester, every LED lights up. I even measured current draw to all individual LED which was around 27 mA.
                        Haven't found any shorts after hours of testing.
                        Inductor is about 4.5 Ohms....
                        06-30-2021, 08:42 AM
