PHILIPS 42PFL8684H/12 led blinks 2 times, dead IC
  • haggitu
    • Nov 2017
    • Estonia
    Hi!
    I have problem with PHILIPS 42PFL8684H/12 tv. First it stoped working and red led started plinking two times over some time. When i opened tv then there was ic FDS6930B burned out, so i changed it with control ic NCP5422ADR2G for that ic. After change when i plugged my tv to wall, some electric sound started to come from power board. Something like wants to star up many tomes and then this ic burns out again, all the time in one place. i have done it 3 times now, no changes. Can it be that all SSB board is faulty and i need to change that? Cant find any more parts that is blown up or any way damaged.
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Re: PHILIPS 42PFL8684H/12 led blinks 2 times, dead IC
    Get the chassis number and try find the service manual. They can be a great help with Philips.
    • haggitu
      • Nov 2017
      • Estonia
      already tried with that, but no help. There is not much talked about power board, more about SSB. Or its to complicate for me to understand that manual there is lot of talked about how to test if that ic that i changed is faulty, but that i already know that it is. Now i jut need to know where can be the reason why it wont start. If tv is plugged in, and i disconnect one ribbon cable where 12v and other useful things go through and i put it back, for few seconds, backlight turns on and then shuts off again.
      Sound what that thing does and how it looks is here: http://www.youtube.com/watch?v=1IO4xJYJhfY
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        Yesterday, 03:47 AM
      • mecha1166
        XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
        by mecha1166
        I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
        07-01-2024, 05:47 PM
      • kew1701
        Philips taw6205 ambilight speaker STM32 mcu dead
        by kew1701
        Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
        04-09-2025, 03:59 AM
      • esqmooo
        HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
        by esqmooo
        Hello everyone.
        This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
        Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
        Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
        I tried long pressing on the power button, after several seconds it would go off then when the button is released...
        03-11-2025, 03:57 PM
      • brithepi2k
        Samsung UE75TU7020k No picture, Standby blinks 2 times
        by brithepi2k
        My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
        04-23-2025, 10:05 AM
