I've been having issues with the backlights failing on this particular model. When these backlights fail (one backlight failure on a strip), the srip will start flashing on and off. I will replace the individual backlights that are defective, test for a day or two, then sell it, only to have it come back within a few weeks with another failed backlight. Is this model known for this backlight issue and is there a fix for it. These particular models keep coming back for the same problem. Thanks in advance for any help offered.
Vizio D50u-D1 backlight issues (Please Help if you can)
Re: Vizio D50u-D1 backlight issues (Please Help if you can)
Originally posted by JunkmanJimbo View PostI've been having issues with the backlights failing on this particular model. When these backlights fail (one backlight failure on a strip), the srip will start flashing on and off. I will replace the individual backlights that are defective, test for a day or two, then sell it, only to have it come back within a few weeks with another failed backlight. Is this model known for this backlight issue and is there a fix for it. These particular models keep coming back for the same problem. Thanks in advance for any help offered.
Just saw your reply, Andrew. Thanks for your help. Actually I have turned down the backlight level on each tv I replace the individual LED's in but that doesn't seem to help. I just recently started to replace all LED strips in these particular models. For some reason, the backlights seem to fail prematurely in this model. I have many other model Vizio's that don't have any backlight issues, just this particular model. I was wondering if this is a known problem with this model. Thank you for your help!
I find Vizio in general suffer from backlight problems. I modify power supply on Vizio. Just adjusting backlights will not really help if you give it to someone else and you cannot control what they do. I have measured current to backlights. And it measures around 430ma at full brightness. Max ratings seem to be about 350ma on these led's. I haven't measured current on other makes that don't suffer led failure. Reducing max. current to around 280-300ma makes me more confident that led's will last.I assume no responsibility for any stupid suggestions I might post.
Here's a couple of threads may help: https://www.badcaps.net/forum/showthread.php?t=61722 , https://www.badcaps.net/forum/showthread.php?t=65978Last edited by dskall; 12-17-2017, 11:48 AM.I assume no responsibility for any stupid suggestions I might post.
