Can anybody help me with this file? The screen is TH420HW06.
Baird CN42bair CV109H V3.0 eeprom bin file U25.
Tags: None
Re: Baird CN42bair CV109H V3.0 eeprom bin file U25.
If you cant find a free copy maybe use ohms supplies
http://www.ohmsupplies.co.uk/BAIRD-C...-PREPROGRAMMED -
Thankyou for your reply.I may have to but all i need is the bin file and not the ic.Ohm supplies will only sell the ic programmed and not the file.If you cant find a free copy maybe use ohms supplies
http://www.ohmsupplies.co.uk/BAIRD-C...-PREPROGRAMMEDComment
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old... - Loading...
