Baird CN42bair CV109H V3.0 eeprom bin file U25.
  • stephenjames
    • Feb 2009
    • 14
    • England
    Can anybody help me with this file? The screen is TH420HW06.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Baird CN42bair CV109H V3.0 eeprom bin file U25.
    If you cant find a free copy maybe use ohms supplies
    http://www.ohmsupplies.co.uk/BAIRD-C...-PREPROGRAMMED
    • stephenjames
      • Feb 2009
      • 14
      • England
      Thankyou for your reply.I may have to but all i need is the bin file and not the ic.Ohm supplies will only sell the ic programmed and not the file.
      • m1ch43lzm
        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
        by m1ch43lzm
        Hi everyone
        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
        There's also an extra OTP Secu.R...
        09-06-2025, 05:47 PM
      • my2k2
        Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
        by my2k2
        Good day to every one,
        I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
        Does anybody have an eeprom dump file? I really appreciate any help.
        Thanks in advance.
        07-01-2024, 09:04 PM
      • Forest79
        by Forest79
        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
        07-23-2023, 07:39 AM
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
