TV Blaupunkt B32FA112BK stuck in standby
  • lepak06
    • Feb 2017
    • 51
    • france
    Hi
    I've an TV Blaupunkt B32FA112BK stuck in standby (red led)
    I can't power on. I checked all voltage . They are ok.
    The first time , i flashed the eprom 25q32 and the tv worked few day.
    One day i unplugged the AC cable and the puggled it then the tv is stuck in red led. I retry to flash eprom and change eprom with another but always stuck in red led.
    Do you have any idea?
  • lepak06
    • Feb 2017
    • 51
    • france
    Re: TV Blaupunkt B32FA112BK stuck in standby
    up
    • lepak06
      TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
      by lepak06
      Hello
      I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
      The TV is faulty with stuck in Standby RED LED. Can't power the TV.
      Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
      All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
      But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
      01-12-2023, 01:43 AM
    • cockalomg
      Blaupunkt blaupunkt b32she188tchd-100 no standby light
      by cockalomg
      Does anyone have a schematic for this board?
      I have no output voltages, no standby voltages.
      The fullbridge rectifier has a permanent 330V
      there is no voltage on the two large black electrolytic capacitors​
      11-05-2024, 03:01 AM
    • toty79
      Hisense LTDN50K220WSEU stuck in standby
      by toty79
      Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
      As per Hisense tv title LTDN50K220WSEU stuck in standby
      PSU rsag.820.5687 HLL 4855WF
      Main rsag 7.820.5842
      I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
      05-01-2022, 04:39 PM
    • lego1234567
      LG 32LB1R - stuck in standby mode
      by lego1234567
      Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
      What could be the problem ? Thanks...
      01-21-2024, 03:39 AM
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
