Sharp LC-32AD5E-BK Vertical sync/Framerate error
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hi guys ,
    A friend of mine has got this Sharp lcd tv. It has a problem with the HDMI input.
    On both HDMI input he gets the error as on the video that i attached.
    The picture on the video should be still but its rolling......
    The fault is not there on VGA/SCART etc , only HDMI.
    I don't have any pictures of the inside yet. Anyone got a idea? Also can someone tell me what cap on the mainboard is causing the startup problems of this model? If i can fix the tv i would like to replace the cap to prevent future problems.
    Thanks.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Sharp LC-32AD5E-BK Vertical sync/Framerate error
    Pictures in this thread!
    https://www.badcaps.net/forum/showth...t=LC-32AD5E-BK
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Anyone got some suggestions? Im leaning towards the caps on the mainboard.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4451
        • Italy - Milan
        Why you zipped the file? Anyway i'm unable to see MP4 files i think.. or Apple movies, but if all the thing i have to know is the image vertically rolls then it is maybe something in the hdmi port config, check the service manual on how to restore DDC eeprom setting.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          I had to zip the file because i can't attach any video format. It looks like the old tv's when you select a channel you had to adjust it to get it steady.
          • ninja_zx11
            Sharp LC-70LE650U vertical black and red bars
            by ninja_zx11
            70" LED TV is Sharp LC-70LE650U.
            Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
            07-07-2023, 11:27 PM
          • valvashon
            Sharp LC19SB24U; red vertical line comes and goes
            by valvashon
            Yes, this is a very old Sharp 19" but I would like to fix it if possible. As you can see from the attached picture there is a single red vertical line.
            Yesterday when I turned the set on, it was there for about 30 minutes then disappeared and did not show up again (set was on for another 3 hours or so).
            Today it was not there when I powered the set on, then appeared after about 15 minutes. Set has been on for about an hour and it's still there.
            From what I have read I'm guessing that this might be the t-con board and not the display itself as it does come and go.
            02-03-2023, 10:02 AM
          • mopenstein
            Looking for Vertical IC for RCA Chassis CTC159L CRT
            by mopenstein
            I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
            Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
            I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
            09-24-2023, 10:41 AM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • AJ2021
            Sharp LC80UH30U Vertical Band
            by AJ2021
            I just moved to a new apartment and now I got a vertical band on my tv. The band is changing colors all the time. Is there a fix for this? If someone has had the same problem and fixed it I would really appreciate the help as I am retired and on a fixed income and cannot afford a new tv.
            I can change any boards and bad caps but I'm not good with a volt meter.
            Thank you very much for any assistance....
            01-30-2022, 10:57 AM
