Samsung LN T3753H Video Issues
  • Emperor Crusher
    • Nov 2017
    • 6
    Hello. I received a Samsung LN T3753H TV from my father-in-law. It works, but the video has some shimmering off colors, especially seen in the reds. The power supply board has 3 caps that are bad with one especially bad. Other entries at this forum indicate that it could be the T-Con board going bad as well. Wanted to check your opinions before proceeding.
    As for my skill level, I'm a computer tech and am handy enough with a soldering iron to replace the caps. I've also replaced a T-Con board in another Samsung TV he handed down to me that was broken and it works fine now. But I know power supplies can hold enough voltage to kill me, so I'm wary to work on the PS board without warnings and assistance.
    Thanks for any help you can provide.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung LN T3753H Video Issues
    Need pictures of problem. You can check dcv across main cap for voltage
    • Emperor Crusher
      • Nov 2017
      • 6
      Here is a pic of the power board. I've circled the bad caps. The two together are slightly puffed. The single small one barely looks like it is puffing out. The single larger one is definitely bad or going bad.
      Thanks for the help.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Replacing bad caps is good first step
        • Emperor Crusher
          • Nov 2017
          • 6
          OK. But, as I don't know what to touch safely, any advice on making my way around the power supply board after pulling it out? Thanks.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Measure dcv voltage across large main cap. If it has been unplugged for a while it should have no voltage
            • Emperor Crusher
              • Nov 2017
              • 6
              Thanks, dskall. Voltage was 0. Replaced the caps, so the power board is OK. But I still get shimmering on colors. T-Con board?
              • dskall
                • Oct 2016
                • 2905
                • usa
                Some pictures of screen with problem would help
                • Emperor Crusher
                  • Nov 2017
                  • 6
                  Here are some pictures. The car shows the poor quality on the side. The explosion shows a lot of the poor colors and pixilation.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Can we get pic. of t-con?
                      Bad Gamma Voltages on the T-CON board.
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
                      • ohren
                        by ohren
                        09-08-2023, 05:24 PM
                      • C152Heavy
                        by C152Heavy
                        Summary for TL-DR readers:
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
                        GeForce RTX2080 Super Aero video gaming card issues help need
                        by sam_sam_sam
                        This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                        Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                        05-07-2023, 08:12 AM
                      • alltvrepairs
                        Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                        by alltvrepairs
                        I have confirmed that I have a mainboard problem.
                        I have tracked no hardware issued on board so might be a software dump required.
                        I have searched a bit but wasn't able to find anything for my screen:
                        Here are some more details:
                        Panel: cy-nn065hgev1h
                        Main: BN94-14180M P08F
                        Your help much appreciated!
                        05-16-2025, 03:03 AM
