Need help with AOC L24H898 service menu color calibration
  • Ifixstuff9
    • Jul 2017
    • 120
    So I have the AOC 24 inch TV that has really screwed up colors. Upon further investigation it appears that the previous owner messed with the service menu and now everything is messed up. I would like to fix the color issues, starting with the VGA input (each input has its own settings), but I have no idea how to. Does anyone know how to properly calibrate the display using the service menu? The values are a mess, maybe someone has an identical TV and they can give me the values?
    Pics comparing the AOC TV to my HP 23es IPS monitor. Both were hooked up to the same laptop in screen mirror mode, so they should look the same:
  • Ifixstuff9
    • Jul 2017
    • 120
    Re: Need help with AOC L24H898 service menu color calibration
    Well, problem solved, everything works as it should now. Turns out the EPROM Init function in the service menu completely resets the TV to the factory default settings, including the color calibration values in the service menu. I'll leave this post up just in case someone else has a problem like this and needs a point in the right direction.
      LCD LED TV Service Menu Codes
      ALL LCD LED TV SERVICE MENU CODES
      Service Menu Code with Board Name
      China Universal Board / Jumper Board Service Menu Code
      Changhong Ruba Service Menu Code
      Ecostar LED TV Service Menu Code
      Orient LED TV Service Menu Code
      Haier LED TV Service Menu Code
      TCL LED TV Service Menu Code
      Samsung LED TV Service Menu Code
      LG LED TV Service Menu Code
      Videocon LED TV Service Menu Code
      Supra LED TV Service Menu Code
      Toshiba LED TV Service Menu Code
      Symphony LED TV Service Menu Code
      Veste/ LED TV Service Menu Code...
      10-31-2024, 03:58 AM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
    • tusiime
      How to access Vizio m652i-b2 service menu
      by tusiime
      The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
      So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
      Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
      09-15-2023, 09:57 AM
    • intercepter
      JVC LT-32CA120 service menu
      by intercepter
      I have JVC LT-32CA120
      Board:Vestel 17MB171
      I need rotate screen.It is possible in service menu and how to enter service menu?
      Thanks.
      12-10-2024, 10:29 AM
    • alltvrepairs
      Jvc Lt-65VU3000 reduce backlight from service menu
      by alltvrepairs
      I have just replaced led set of this vestel tv due to age.
      I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
      Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
      Thanks again....
      09-20-2025, 05:03 AM
