Asus PB258Q no screen, looking for a EEPROM
  • dan1200rr
    • Apr 2014
    • 9
    • Poland
    Hello, the monitor goes on but no screen is displayed (and the backlight), I'm looking for a working eeprom. I've changed all the caps.
    The mainboard model is: 715G6767-M0C-002-005K
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • FallenOne008
    Asus G712L No Screen Backlight
    by FallenOne008
    Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
    The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
    03-31-2025, 08:27 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • krige
    asus g750js ms1130c (203) turns on nothing on the screen
    by krige
    hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
    03-22-2024, 04:59 AM
  • Technodoc
    ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
    by Technodoc
    Asus laptop G614JZ-N3012W Rog Strix with i7
    Mainboard G634J-PMV-VGT
    6050A3441302-MB-A01
    2023-02-10
    Power button works okay....power light goes on
    Red "bottom" leds go on
    Charging led works
    Fans do not spin, capslock key does nothing, screen stays black
    I would like to program the bios again, to rule out a corrupted bios.
    However I run into a size error
    The bios chip is a Winbond 25R256JVEN
    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
    02-24-2025, 04:46 AM
