LG50PT353k
  • finntricky
    • Jan 2014
    • 449
    LG50PT353k
    Hi Guys,
    got this LG plasma, with flashing stand by, took the back off, and it was so thick with sticky fluff, so took out the power supply to clean it up before checking voltages, put it back in and the tv came on, but with very spotty pic, then took out Y-SUS, again, gave it a good clean up and put it back in, turned the tv on, and BINGO, turned on great picture.
    so im thinking to my self, nice easy repair job this is, took out the rest of the boards, give them all a good cleaning and then reinstall,
    turn the set on and, you guessed it, no pic, no screen flash, but the tv turns on and has sound though a scart.
    checked all volts and every one seems to be correct,
    cant find any shorts on buffers, but has i have no flash of the screen, im thinking X-SUS,
    oh, by the way, the led on the control board gives 4 flashes, the 3rd flash lasts longer than the first 2, and the 4th is quick, if that give any idea.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG50PT353k
    I would be tempted to reseat all the boards once again in the hope that one of the connectors are not quite in place.
    • tw2005
      • Oct 2011
      • 6457
      Re: LG50PT353k
      So where has the centre ribbon to the ZSUS disappeared to? Under the sub board?
      • tw2005
        • Oct 2011
        • 6457
        Re: LG50PT353k
        Actually, just doing some extra research. It only has 2 ZSUS ribbons? found the sub board which is different to yours but suggests a running change in production.
        , certainly not something I've seen before.
        • finntricky
          • Jan 2014
          • 449
          Re: LG50PT353k
          what sort of voltage should i be getting at the point x-sus to ribbon board ?, i only get 4 volts, that can't be right,
          testing fets and some of the reading are strange, but take them out and test ok,
          • tw2005
            • Oct 2011
            • 6457
            Re: LG50PT353k
            Not sure on this one but may be worth pulling the boards or at least the ZSUS and closely inspect th esolders particularly on those big coils. previous models have cracked through causing erratic behaviour and then the usual snap crackle and pop for a few IGBTs.
            Kinda been working on some LGs lateley(forgive me) Panasonics all dried up because some fool has spread so much info on how to.
            • tw2005
              • Oct 2011
              • 6457
              Re: LG50PT353k
              Is the TV running or in protect? Are the YSUS volatages normal?
              • finntricky
                • Jan 2014
                • 449
                Re: LG50PT353k
                all voltages at test points are spot on, give or take a volt or 2.
                and the tv boots fine, with sound and no picture
                • tw2005
                  • Oct 2011
                  • 6457
                  Re: LG50PT353k
                  Well it was working, now not, If the volatages are correct on the ZSUS test points too I'd check th eboard then maybe try thr old ctrl bd jumper screen test with the main isolated. can't be much though if you had it and now lost it.
                  • Hamie
                    • Apr 2014
                    • 1383
                    Re: LG50PT353k
                    I had one if these a while ago with no picture.
                    Turned out to be a cracked joint on the transformer located on the ysus.
                    Might be worth having a look
                    • tw2005
                      • Oct 2011
                      • 6457
                      Re: LG50PT353k
                      should also mention that if the ctrl bd craps itself, you'll see nothing but will have sound. that's the issue with the one I've got, don't remember if the panel primes up or not, if I try really hard I can get some
                      • finntricky
                        • Jan 2014
                        • 449
                        Re: LG50PT353k
                        checked all the solder joints, and tried the auto gen, still nothing, think ill gumtree it, let someone else have a go, not worth spending money on a 720 plasma
                        • tw2005
                          • Oct 2011
                          • 6457
                          Re: LG50PT353k
                          Yeah, that's how I feel but if a ctrl bd surfaces real cheap, I'm in business.
                            • 12075
                            • U.S.
                            Re: LG50PT353k
                            Have the exact same led blinking on control board on a 50PT350: "the led on the control board gives 4 flashes, the 3rd flash lasts longer than the first 2, and the 4th is quick": also had a IC110 burnout on YDRV upper buffer, replaced the buffer, now have the control board blinking, no picture. Anyone ever figure out the problem, bad control board??
                              • 12075
                              • U.S.
                              Re: LG50PT353k
                              jumped the auto gen, no patterns just black, during auto gen jump the red led on front, when I power on goes red then fades out then 2 seconds later comes back on and stays on, relay clicks about 4 times sometimes more.
                                • 12075
                                • U.S.
                                Re: LG50PT353k
                                found 4 bad transistors on x board heatsink and D10 shorted, replaced them, still no picture no glow, there is a steady red standby led on front that goes off when I hit power, relay clicks once, have voltages but no picture or glow, just black blank screen.
                                  • 12075
                                  • U.S.
                                  Re: LG50PT353k
                                  rechecking z board, I called it x above, checked the transistors I replaced, getting short to ground on Q107 collector, Q110 collector and two pins of D114 also short to ground, not sure if that is normal, anyone have an idea of what might be the cause or what to check, thanks, picture from sj:
                                  https://www.shopjimmy.com/lg-ebr7173...01-zsus-board/
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    Re: LG50PT353k
                                    Bad transistors (igbt's) on the z main will take out transistors on the y main, and vice versa. The boards are chained together. Replace all bad transistors.
                                    • corrize
                                      Nikon D800 camera - flash don’t work and capacitor don’t charge
                                      by corrize
                                      Hello, I'm stuck in troubleshooting…
                                      The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                      In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                      When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                      10-01-2022, 10:02 AM
                                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                      by sam_sam_sam
                                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                      I am comparing them to a brand new one that I installed
                                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                      I going to let it run for several days before I remount back on the wall next to the...
                                      09-05-2024, 06:48 PM
                                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                      This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-12-2024, 02:30 PM
                                      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                      HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                      09-06-2024, 08:10 PM
