Tv is dead, no light, by holding power on can get light on, but no sound or picture (Screen Black)
Need schematic for a Hitachi LE42H508A
Tags: None
Re: Need schematic for a Hitachi LE42H508A
Maybe this thread will help :
https://www.badcaps.net/forum/showthread.php?t=38225
by noipigood day, anyone can help me the schematic of surface go 2 (da0v81mbae0). The problem is no display LIGHT.
09-21-2023, 08:36 PM -
by sam_sam_samI have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
I also have back when Light of America had these light bulbs available for yard lights
The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
While the Lithonia lighting fixture has all most certain bulb failure
So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
I have only had this light fixture for not more than a year if it... -
by esqmoooHello everyone.
This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
I tried long pressing on the power button, after several seconds it would go off then when the button is released... -
by sam_sam_samSo I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line... -
by DXseekerMOHello everyone!
Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
Symptoms:
1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
2) TV does not appear to turn on
3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
4) "Power on" terminal on Power Supply has 3.26v
5) "A13V" terminals have 12.9v
6) Stand-by test jumper on Power Supply has 12.9V
7) Optical audio jack on Main Board illuminates
8) With stand-by... - Loading...
