Hitachi LE42H508
  • mike123333
    • Oct 2011
    • 196
    Hitachi LE42H508
    Hello everyone, I have an Hitachi LE42H508 that I recently acquired that does not have a backlight. At first the TV would not turn on or go into standby. I went inside to perform some preliminary evaluation and checked the voltages on the high capacitor and found there to be the ~300V DC. Then pursued with the 12.4 volt marked on the PS and that was fine. While conducting the measurements I noticed Diode D107 ( was not shorted) was smoking and the cooling rail for the transistors was extremely hot to the touch, needlessly to say i turned off the set. Upon ohm measurement I found rectifier diode to be shorted D305. So i removed it from the circuit and powered on the TV and the TV went into standby mode and turned on and there was video( using a flash light I can see it). after pulling off D107 it seemed the smoke was from the heat coming off the diode and melting the coating on the board.
    I ordered the diode D107 ( FR107) and D503(UF5408)....The D107 diode ws part of package of many different types. One type was the 1N5408, I decided to install both diodes and check the TV...at first I did not hook up the LED cabling to the board. I tested it and noticed nothign happening I measured the voltage and only seen a spike..So I hooked up the LED cable and turned on the set, the back lights came on then shut off then no TV...after measuring the ohms across the diode D503 it turned out it shorted again.
    I went ahead removed it and replaced a new one but did not hook up the LED cable, turned the TV on and there was no standby LED on or the TV would have picture.. I then measured the voltage going to the LED and there would be a spike to 150V DC and then steadily drop to 0..
    I removed the diode D503 and the video worked and standby LED was present..
    Does this sound liek there is something on the primary side of the tranformer for the LED backlights? why would the primary get so hot and secondary short? I took the transformer out of curcuit and tested it for shorts, there were no shorts between primary and secondary windings.
    Any input would be greatly appreciated..I checked out the board components as best as I can with my limited experience and found no diodes shorted or capacitors with issues, I did check with my ESR on the capacitors and found no issues, unless its happening under load. I have included photos of the PS.
  • mike123333
    • Oct 2011
    • 196
    Re: Hitachi LE42H508
    I wanted to include some additional information I gained with measurements, at the main DC capacitor filter I am getting around 380V with TV in on position and 168 V in standby..as I probe around the transformer for the LED the diode D107 on the non band side is at 380V and the other side which is tied to resistor R123 a spike of over 600V then drops to between 450v AND 550v i am using the main filter negative lead as the ground on the hot side. one side of R123 is at 380V and the other is in that range of 450v to 550v ..does this possibly question the transformer???
    • R_J
      • Jun 2012
      • 9588
      D107 must be a Fast recovery diode, D503 is ultra fast diode, if you put in the general purpose 1n5408 it will get hot and most likley short out.
      Without a schematic it's hard to tell (from the pictures) where those diodes go.
      • mike123333
        • Oct 2011
        • 196
        Thanks for the reply..I am awaiting the delivery of my UF5408, I just wanted to test the circuit to determine if anything else was at fault....I do have a question regarding the transformer, why are they using the DV voltage on the primary side of the transformer? that is all I can measure, when I put my meter in AC I do not get any measurement across the transformer primary. all the reading I have done was that the primary is AC and secondary is DC with a rectifier diode. am I missing anything here?
        • R_J
          • Jun 2012
          • 9588
          On the primary side the raw dc is converted to high frequency ac to drive the transformer. (it is more complicated than that but thats basicaly it)
          These transformers rarely go bad, It looks like one transformer is used for standby and one is for the back light, Once you have the correct diodes replaced it might work fine.
          The ac is at a high frequency maybe around 50Khz your meter may not read this.
          On the bottom of the board it looks like the primary circuits are within the black circle, look up the 8 pin ic's data sheets, they may give you more information about how they operate.
          • mike123333
            • Oct 2011
            • 196
            I received the correct UF5408 diode soldered it in above the board like I have in the picture in a previous post (to reduce heat buildup, the originally was flat with the board) and all is well....I am wondering whether there may have been a mnfr defect, the TV ws manufactured in March 2014.
            • rustytierod
              • Sep 2014
              • 81
              Just came across this exact problem, did you mean D305? I cannot find D503 on the board...
              • dskall
                • Oct 2016
                • 2905
                • usa
                Looks like D305 from picture.
                • rustytierod
                  • Sep 2014
                  • 81
                  Trying to find alternate for this UF5408 diode. What's the important spec besides "ultra fast," does anyone know if UT3060 qualifies?
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    UT3060 is not a fast recovery diode. UF5408 is a very common diode so you should be able to easily find it. Most important specs are: similar or higher reverse voltage, similar or higher forward current, similar or lower reverse recovery time (which is why it is called "ultra fast"). Try to have a forward voltage not too far off too.
                    If it's not a fast recovery diode, they usually don't give the reverse recovery time in the datasheet. It does matter only when it's in a fast switching circuit (for example SMPS secondary rectifier like here).
                    • asr
                      Finding replacement diode iPad Pro 3rd gen A1701
                      by asr
                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                      07-09-2024, 06:24 PM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                    • NicRac
                      monowheel repair,Is the diode the problem?
                      by NicRac
                      Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                      First of all, I am new here. Therefore I will shortly introduce myself.
                      I am Nico and currently I study Physics.
                      In my freetime I like to build and repair stuff. Especially big battery's.
                      A few years ago I got myself an electric unicycle, monowheel or however you call that.
                      The battery bms was broken so I replaced and resolder that. Nothing big.
                      I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                      07-26-2024, 06:13 AM
                    • dennis_elx33
                      NO BODY MARKING Diode
                      by dennis_elx33
                      Hello Everyone,
                      I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                      While compared to the reading of another diode from the next channel it won't read at reverse bias.
                      Now the problem is; it does not have any body marking.
                      So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                      What do you think is this diode?
                      Can you please suggest what part number can i use to replace this faulty diode instead?
                      Hoping that you...
                      06-14-2024, 12:36 AM
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
