Strange bootloop - Funai LED TV 29FL553/10N
  • Folxs
    • Nov 2016
    • 167
    • Poland
    Hi, I got Funai LED TV 29FL553/10N
    It turns on, draw 27.5W from wall outlet and reset again.
    What could it be? Caps in power supply are visible good - two biggest I measured ESR and capacity and it's ok.
    Could it be EEPROM failure? Maybe someone had similar problem?
    Video with power meter:
    https://youtu.be/pE_0rHrP1Ig
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Strange bootloop - Funai LED TV 29FL553/10N
    Do you get a logo and do you see it freeze before it reboots?
    A freeze and an auto-reboot is likely an OS panic due to corruption, especially Android.
    If it just seems to keep turning off and coming back on, reflow the PSU solder joints, including the primary...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Folxs
      • Nov 2016
      • 167
      • Poland
      I see logo for a couple seconds - I uploaded YouTube video how it looks.
      I dont know if it is android - I dont think it is even smart TV.
      After logo turns off it stay black with backlight for few seconds - so I dont think it freezes
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It look like you have a blown mosfet and possible ceramic capacitor.
        • Folxs
          • Nov 2016
          • 167
          • Poland
          It's just dirt (dust and cigarettes smoke)
          • diif
            • Feb 2014
            • 6978
            • England
            I've had similar, TV showed boot logo then restarted, and showed logo and restarted and repeat..
            Was the eeprom at fault. Flashed and all was well.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              My Samsung Galaxy S5 one year ago did that, IIRC, it suddenly developed a random reboot problem, including when playing music and then it randomly would fail to boot completely. Randomly, it would freeze at the Samsung logo and I was like, WTF!
              The only fix was an Android factory reset and possibly was a poorly contacting mini SD card as well. :/
              The problem with that, was this, not even a kernel panic error message! Apparently, because they (Google) wanted to copy Microsoft's NT family, where it just reboots instead of showing an error screen.
              The auto-reboot feature was introduced in Windows 2000, if not Windows NT 4.0 or NT 3x...
              Arc A770 16 GB
              • Folxs
                • Nov 2016
                • 167
                • Poland
                Ok, I will try to reflash eeprom
                • Folxs
                  • Nov 2016
                  • 167
                  • Poland
                  Reflash helped for a while - now I turned on the TV and the same bootloop. I think that the chip is broken itself and it lost data again, what do You think?
                  I will try if the new chip will help - maybe something drifferent causes erasing the chip?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    The chips do fail. Just flash the dump you have to a new chip.
                    • Folxs
                      • Nov 2016
                      • 167
                      • Poland
                      It's working! New FLASH chip helped!
                      Thanks a lot for sugestions! Especially diif
                      Below I uploaded FLASH Dump for this TV (thanks to zdzifu from elektroda.pl forum):
                      FUNAI 29FL553/10 (mine was 29FL553/10n)
                      Motherboard: T.MSD309.B95 flash 25Q32BSIG
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        You're welcome, glad you got it working.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Well done. I've added your EEPROM dump to the EEPROM thread.
                          • Folxs
                            • Nov 2016
                            • 167
                            • Poland
                            Thank You very much
                            • reassor
                              Sony kd70xf8305 very very slow android logo with sound
                              by reassor
                              Hi.
                              Power is ok
                              Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
                              Should i force update? If so how?
                              I did reset.
                              Mainboard Looks pristine.
                              Very wierd.
                              10-30-2023, 05:59 AM
                            • Ihandyrepair
                              4 red flash led 65X950G boot Sony and android logo but then black
                              by Ihandyrepair
                              HI guys
                              I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                              here is the issue
                              I have Sony and android logo. but then 4 led red flash lights front of the tv
                              I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                              but then I get black screen and 4 red flash light at the front LED
                              but I get 3 led flash on the LED driver board.
                              I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                              so I tried...
                              07-11-2024, 01:45 AM
                            • Teban1306
                              [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                              by Teban1306
                              Hello everyone!
                              I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                              System Information:
                              • Model: Lenovo ThinkPad T14 Gen 1
                              • Machine Type: 20S1S4E600 (Intel i7 variant)
                              • Current BIOS: N2XET42W (1.33) - Latest version
                              • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                              What I'm trying to achieve:
                              Replace the default "LENOVO" boot logo with a custom image during POST.
                              🔧 What I've tried:
                              09-14-2025, 11:49 AM
                            • kotel studios
                              Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                              by kotel studios
                              Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                              State I got it in:
                              Squealing from the PSU
                              After logo I get a blank screen
                              After 10 seconds of having a blank display w/ backlight the TV dies
                              Give it 7-10ish seconds again and it starts to bootloop.
                              What I did so far:
                              Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                              Checked all voltage rails:
                              5VSB - 4.8V
                              AMP+13V - 14.4V
                              13V - 12.98V (in manual 12V)...
                              09-21-2025, 02:00 AM
                            • Verlengsnoer
                              Bios splash/logo change
                              by Verlengsnoer
                              at firs, i hope this is the right place to post my question.
                              Im looking for a tool to change the bios logo.
                              everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                              i know that HP has a build in option to change the splash logo.
                              but i want to change the manufacturer logo to an own logo.
                              I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                              10-28-2022, 09:52 AM
