Samsung 69" LED no power issue
  • Wellington1
    • Sep 2017
    • 43
    I posted earlier regarding my Samsung 60DUN6420UF turning off after about 1 minute, during which the panel itself and led lighting are fine, with no devices connected of course there is a " no signal detected" on the screen along with another "no hdmi2 " icon.
    Interestingly the tv turns itself on automatically once plugged in to an ac outlet after perhaps 15 = 20 seconds. After about 30 seconds the screen will evenly fluctuate, or more precisely the edge lit leds and then the on screen display will begin to bounce, some lines appear all over and then it quickly shuts down, doing the relay cycling or clicking every 20 - 30 seconds on the PS board.
    I did notice after unplugging the tv for 15 minutes and then plugging it in again that when it self powered there were various unevenly spaced horizontal lines or bars of different solid colors - blue, red or green that also stated bouncing and again it turned off after perhaps a minute. There was no OSD this time, just the lines, including a blue one along the top edge that was had an even square block pattern.
    Normally there is no front power indicator but when I unplugged the tv the second time the relay began clicking twice, it did this three times in succession with maybe 10 seconds between each "cycle" and this time I noticed that the front power indicator was flashing red twice at the same time as the relay. There was no on screen display present.
    I know the panel and back lit leds are good but trying to figure out the function of the pins on the connector to the main board for voltages. Not much information on that so far though I do see values printed on the edge of the PS board. The Samsung PS board part # is BN44-00425A.
    Does any of this sound familiar to anyone here? I have yet to test anything, though no real experience. have a digital multi meter. Should read 60" in title - typo error!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung 69" LED no power issue
    Need good clear straight on pictures of whole back of tv with cover off and each board.
    • CapLeaker
      Leaking Member
      • 8352
      also recheck that model number from the TV
      • Wellington1
        • Sep 2017
        • 43
        I appreciate the help - it is a UN60D6420UFXZC ( XZA IN U.S. ).
        Maybe check that post as I just replied to some advice from earlier.
          Should stick to the original thread instead of making this new thread, it will cause less confusion.
          https://www.badcaps.net/forum/showthread.php?t=64411
          • Kjell
            Samsung Series 9 - BIOS issue
            by Kjell
            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
            08-01-2025, 09:15 AM
            09-07-2024, 05:50 AM
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • eigma
            Samsung UN40H5003 boot loop every ~8 seconds
            by eigma
            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
            Main board: BN94-07592P / BN97-08922R...
            11-20-2024, 10:31 PM
