37PFL5522D/05 philips 2 red flashes code
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    this is one i have repaired before by putting in a new audio chip . it worked for months but has now come back .
    first removed audio chip like last time but no joy .
    installed a second hand main board and now it tries to come out of standby .red light goes blue for a few seconds then red light blinks twice . supposedly means 12v low or missing . which it is along with other voltages after trying to power it up .
    all supply voltages are good to start with .
    at no time do the backlights come on .. am wondering if i can try and force backlights on and how to do it ?
    the speakers pop when its trying to power up . i measured 900mv at one speaker but not sure if its that shutting it down .
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: 37PFL5522D/05 philips 2 red flashes code
    do the back lights switch on high or low ? if i can check this it will give me a direction to go in
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      can anyone offer any help with this please ?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Can you post pictures of the boards and give the various voltages that are labelled alongside any connectors that you have measured. What's the power supply part number?
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          its a delta DPS-168BP power board
          back light inverter is on power board
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Connect CN6 Pin3 (BL_ON) to CN7 Pin 4,5 or 6 (5VS) and also CN6 Pin 6 (PSON) to CN7 Pin 4,5, or 6 using 1K resistor for each.
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              ok tried that .
              no backlight
              voltage at bl on is dropping to 1.2v through the 1k resistor .. ps on keeps 5v ok .
              so i guess 1k is too high or something is pulling too much current .
              p.s this board doesnt have cn2 and cn3 shown in you picture .
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Some pictures of your boards would be useful.
                This may be your power supply. Two sheets shown on the thread.
                Hopefully this matches your power supply. So again jumper standby to BL_ON and standby to PSON
                https://www.elektroda.pl/rtvforum/topic2355632.html
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  looks a bit different .this one is dps-168bp ..then b for 37 inch .
                  will try taking a pic but i really need sunlight
                  • ducky29
                    • Dec 2015
                    • 370
                    • Europe
                    Replace the diode that is next to the watermark(below 3 optocouplers)
                    https://spares2repair.co.uk/bmz_cach...ge.489x600.jpg
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      pics attached i hope
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        diode tests fine
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          been rooting through the internet and got pointed to ic201 .fa5531
                          i just tested it for shorts and it appears shorted pin8 to pin 6 . looking at the data sheet it shouldn't be connected or appear to be with other components . i will have to remove it for further testing .
                          am still hunting for the schematic for this board . and now a fa5531 ic .
                            What is this TV chassis number?
                            LC7.1E LB????
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              well it needs a new power supply now ..
                              my mistake .. i removed ic201 and found pin 8 and pin 6 were connected on the board .soldered it back in and didn't check for shorts . big bang and a flash . now the board is burned up .
                                LCD LED TV Service Menu Codes
                                ALL LCD LED TV SERVICE MENU CODES
                                Service Menu Code with Board Name
                                China Universal Board / Jumper Board Service Menu Code
                                Changhong Ruba Service Menu Code
                                Ecostar LED TV Service Menu Code
                                Orient LED TV Service Menu Code
                                Haier LED TV Service Menu Code
                                TCL LED TV Service Menu Code
                                Samsung LED TV Service Menu Code
                                LG LED TV Service Menu Code
                                Videocon LED TV Service Menu Code
                                Supra LED TV Service Menu Code
                                Toshiba LED TV Service Menu Code
                                Symphony LED TV Service Menu Code
                                Veste/ LED TV Service Menu Code...
                                10-31-2024, 03:58 AM
                              • eurgenca
                                Philips TV 43pus7505 setting display option code, help please.
                                by eurgenca
                                Hello.
                                I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
                                So I ordered a used CPU board, and now I have wired picture.
                                I think the problem lies in display option code. According to SM, the command for setting
                                display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
                                But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
                                or can I manually edit option code in SAM.​
                                10-07-2024, 02:09 AM
                              • diazald
                                philips 55pfl5907/f7 flashes and goes black
                                by diazald
                                Hi Guys I have a philips 55pfl5907/f7 Backlight flashes and then goes black Protection Mode I assume. This set has a LED Driver board and is Edge lit (Only 2 light strips). I put my LED checker on the connection and get 103v on 7 of the segments and 112v on the 8th segment. Obviously theres an LED out on that segment but still lights up.
                                Could such a small voltage difference cause the set to go into 'protection Mode'?
                                Thanks in advance
                                Will
                                11-04-2023, 01:28 PM
                              • Sorrow1
                                Intergraph TDZ 2000 mainboard post code 2F/2E
                                by Sorrow1
                                I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                                It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                                When I recorded video of POST card and played it in slow...
                                01-03-2024, 04:13 AM
                              • DynaxSC
                                MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                by DynaxSC
                                Hi Folks
                                I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                09-29-2024, 04:27 PM
