Westinghouse LD-3255VX Half Of Screen is gone?
  • Vitam
    Class A Geek
    • Aug 2017
    • 45
    Hi! Firstly, this is a repost. I posted this before but it got pushed a few pages back. So, I have a Westinghouse LD-3255VX 720p 32" LCD TV. It came out of a bar or club, that's all I know about it. Was given to me. So, the bottom half of the screen is black and has vertical colored lines. I have reseated all cables, resoldered the LVDS connector on the main board, (main board is OK). I also took the front frame off to check the tabs - nothing happens when you press them or tap them. Nothing when flexing the panel, no evident signs of damaged components on any board. What could the problem be here?
  • Vitam
    Class A Geek
    • Aug 2017
    • 45
    Re: Westinghouse LD-3255VX Half Of Screen is gone?
    • Vitam
      Class A Geek
      • Aug 2017
      • 45
      https://s26.postimg.org/td6hd1uyh/unnamed.jpg
      • proudpolak25
        • Oct 2017
        • 9
        • usa
        Can you see anything in the bottom half at all? Or is it pure black?
        • Vitam
          Class A Geek
          • Aug 2017
          • 45
          It used to have color streaks but now it is pure black.
          • Vitam
            Class A Geek
            • Aug 2017
            • 45
            I just got angry and threw it off the balcony. I'm just stressed at this. Fuck it.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Yep, it got chucked alright, LOL!
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Vitam
                Class A Geek
                • Aug 2017
                • 45
                I think the panel was water damaged, judging by the debris!
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Well if it's any consolation it was probably bad panel. Thus not repairable.
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • valvashon
                    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                    by valvashon
                    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                    11-24-2024, 12:08 PM
                  • Raulnn
                    TD Systems K50DLG12US half black and half white screen
                    by Raulnn
                    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                    01-20-2024, 04:49 PM
                  • scubacamper
                    Sharp Aquos LC-70C6400U Half Screen Dark
                    by scubacamper
                    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                    05-03-2025, 12:19 PM
