Seiki / Panasonic TC-55CX400U main board substitution and firmware swap?
  • g20zoom
    • Sep 2017
    • 13
    I believe I've narrowed down my dead TV to the mainboard.
    I have Panasonic TC-55CX400U led tv which I believe is made by Seiki, and probably equivalent to the Seiki SE55UGT as these have the same mainboards.
    How would I go about copying the EEPROM? That way I can use the Seiki board which is cheaper but still come up with the Panasonic logo and use the remote. Someone mentioned there is code on the EEPROM, that a USB firmware upgrade would not overwrite.
    Another option I wanted to explore, was to use a Panasonic 50" board with my 55" TV. Since they are from the same TV series, will just loading the 55" firmware over the 50" firmware on the board by USB be fine?
  • tw2005
    • Oct 2011
    • 6458
    Re: Seiki / Panasonic TC-55CX400U main board substitution and firmware swap?
    http://www.shopjimmy.com/westinghous...-see-note.htm#
    Well if you were skilled at soldering you could physically swap
    • g20zoom
      • Sep 2017
      • 13
      Thanks for the link and info in the other post about how to copy the EEPROM. Interesting stuff. That's the board with the right version, just different model. Unfortunately I'm not skilled enough to solder that stuff.
      I think my current board has a bad EEPROM though. I've read that the NAND flash goes bad on the lower end models. It seems to have the symptoms of it, powers on, see the logo, then shuts off after a few minutes. remote doesn't work, only physical button on the tv does. Also screen looks fine during the firmware update, but keeps rebooting, and reloading the firmware. So seems to be a sign it can't write/save the firmware.
      I'm still debating which route. I could just take the same board, but of a different brand and deal with the logo and new remote. That should work in theory. Or wait til the right deal pops up...for the exact board from my TV.
      • tw2005
        • Oct 2011
        • 6458
        Yeah , I was eyeballing that Toshiba NAND Flash as the likely one to swapover to change it to panasonic but if the panasonic is corrupted copying data is likely to transfer the fault.
        • g20zoom
          • Sep 2017
          • 13
          TV fixed!
          Since Seiki is the OEM manuf. for this Panasonic TV, I went with the 55" Seiki mainboard with the same board/version number. Turns out it actually had one less USB port, which I missed in the pics, but it still had the usb 2.0 port, so all was good.
          It powered up with the Seiki logo, and all seemed to work fine. I didn't have a remote...nor a universal one, so I said what the heck..and I used the Panasonic firmware for my TV. The firmware upgraded, it rebooted in a color check of green/white/red/blue/etc...and kept cycling! slight panic mode, but I powered off and removed the USB with firmware. Rebooted, Seiki came up, but when I went to the menus, it's now Panasonic.
          Anyways TV is working great now!
          • tw2005
            • Oct 2011
            • 6458
            TV fixed!
            That's funny , pity you did not take some pics or a video. Shame about the USB, I did not see that either. Is it in the menu to select? maybe you could add it?
            • l3emarsh
              Firmware needed for A Panasonic TX-55FX555B 4K HDR TV
              by l3emarsh
              I have a Panasonc/vestel 55" 4K HDR TV and I need A copy of the Firmware.
              I replaced the main board and someone gave me a 43" FINLUX firmware as it is a Panasonic Vestel version, it got the TV working again but the PIP will not work, I can only assume that it's because the Firmware thinks it is 43" tv?
              I was greatfull for the TV to be workng again and it's been okay, but now I want to get it set up correctly.
              If anyone has a copy of the firmware I need PLEASE help me out and send me A copy.
              Greatfull for any help.
              01-11-2022, 07:44 PM
            • TheUser
              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
              by TheUser
              Hello to everyone ,
              This is my first post here, and i would like to share with you a small story in case you can help me.
              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
              02-10-2024, 02:07 PM
            • gurj1979
              Ubiquiti firmware help. US-8-150W POE
              by gurj1979
              Hi guys.
              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
              Got New chip and writes good.
              THE PROBLEM...
              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
              Does anyone have a Good Firmware I can have?...
              07-22-2024, 05:13 PM
            • Chrissygizmo
              panasonic tx-55fx555b firmware issue
              by Chrissygizmo
              Hi all, am posting this for a friend so I don't have any photos of boards or anything, I know I should have all the information at hand with photos etc but I just thought I would try to find him the firmware he needs, I saw a thread on here where a user named "Diah" sent links to "l3emarsh" for the same firmware...
              Basically, the standby light is constantly flashing & after reading posts on different sites I've come to the conclusion that it most likely is the firmware...
              Any help would be appreciated
              Thanks in advance
              07-28-2022, 05:16 PM
            • wattage
              by wattage
              Hello Badcaps Community,
              07-13-2025, 04:41 PM
