Philips 42PFK6589/12 blurred colors and picture upside down.
  • Trtu
    • Nov 2016
    • 14
    • Estonia
    Got a three year old Philips 42PFK6589/12.
    The previous owner said that one day TV went black, after couple months he turned TV on and got this blurred/inverted picture.
    I think blurred colors is caused by bad tcon.
    Picture is half black/half white If I remove left LVSD from tcon.
    Picture is half blurred/half white if I remove right LVSD from tcon.
    What causes upside down picture?
    TV has latest firmware.
    For some reason the factory reset from the menu does not work.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4462
    • Italy - Milan
    Re: Philips 42PFK6589/12 blurred colors and picture upside down.
    It looks like the main board have a messed up configuration, especially panel type and flip function or tv model, there's a remote possibility of ruined content of tcon eeprom. go into the sam menu and put in option codes from the back cover of the tv.
    • Trtu
      • Nov 2016
      • 14
      • Estonia
      Yes, you are right. Six 3-digit codes are messed up (picture 1).
      I changed thme to the correct ones (picture 2), but I can not save the changes.
      From the service manual:
      How to Store SAM Settings
      To store the settings changed in SAM mode (except the
      RGB Align settings), leave the top level SAM menu by using
      the POWER button on the remote control transmitter or the
      television set. The mentioned exceptions must be stored
      separately via the STORE button.
      So, I am in the top level menu, (like in the picture 2), I push the power button and TV just turns off. After turning on nothing changed. I do not have STORE button on the remote, so tried every button to save changes, but no result.
      • vinceroger69
        • Mar 2012
        • 6714
        is your remote a original one of aftermarket one i would of guessed its the ok button on your remote control uless there is a service remote control like lg tvs that need one
        • Trtu
          • Nov 2016
          • 14
          • Estonia
          Original, and the OK button does not save changes.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you just do a firmware update to correct it or not?
            http://www.p4c.philips.com/cgi-bin/c...n=42PFK6589/12
            • Trtu
              • Nov 2016
              • 14
              • Estonia
              Thank you for your advice. Did that with USB stick, but no luck.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Can you do a factory reset?
                http://tips-trick-electronic.blogspo...vice-mode.html
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4462
                  • Italy - Milan
                  Try to use Store item if not work change mainboard eeprom and retry..
                  • Trtu
                    • Nov 2016
                    • 14
                    • Estonia
                    Thank you everyone for help.
                    TV working again.
                    What I did?
                    From factory mode changed panel id to the correct one and changed panel flip to off. There were some other incorrect entries what I changed.
                    • geeko
                      • Jun 2021
                      • 14
                      • Armenia
                      Dear group mates I have the same TV, it's not turning on, only red colour indicator and Philips word lighted, I checked all voltages, but all are normal, only one thing interesting that CPU get hot, client said that TV was working normal then he turns it off then he can't turn it on again, Any advice?
                      • Rauni
                        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                        by Rauni
                        Hello, this is my first post on this forum, and my first attempted to repair a TV.
                        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                        Read also that we should test what happens if we...
                        10-01-2023, 12:06 AM
                      • madyoyo
                        Philips 37pfl560: Yellow picture
                        by madyoyo
                        HI.
                        I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                        Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                        05-30-2025, 10:16 AM
                      • charlesdutcher
                        No picture issue in Philips Chassis FTL2.1
                        by charlesdutcher
                        My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                        Is there someone having any symptom like this? How to fix it?
                        Thanks in advance!​
                        08-06-2024, 09:55 PM
                      • garrymc123
                        Luxor TV board input board change but picture upside down
                        by garrymc123
                        Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
                        Is there anything I can do to flip the picture or do I need to change the board again..
                        Garry...
                        08-29-2022, 04:53 AM
                      • groomit
                        Philips 50PUS7363/12 Backlight but no picture
                        by groomit
                        I'm having trouble with above mentioned TV. Bought it defect.
                        Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                        Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                        I can see backlight, but screen stays black.
                        What I've tried:
                        - Disconnect right side cable from T-Con -> same (backlight but no pic)
                        - Disconnect left side...
                        11-22-2024, 02:43 PM
