Samsung LN46B650T1F mo backlight red led on
  • ivtec
    • Dec 2008
    • 1967
    Hi guys i picked up today this Samsung LCD LN46B650T1F no backlight and red led on,
    so far what tested,the 2 big caps side by side each 168v,the bridge rect has 79v
    all fuses Diodes and other componets that i could check seem ok,
    i don't have the supposed 5v,13v,5.1v, volts at CN801 going to main board.
    I checked a couple SBRF'S in the circuit that seemed suspected,i took them out and they seem OK ? not sure,i sent a pic of the Scheme i made measured with diode function,are these OK?.
    Also there is a SM Q-50P04 that i circled on the other side close to the SBRF's
    that seems to be bad? it measures OL between all legs?
    do you know anything about this TV? can you share some of your knowledge,
    Also the other side of the board where Inverter transformers are is kinda dark ?thanks
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung LN46B650T1F mo backlight red led on
    What's the board number BN44-2xxxx
      BN44-00265B, see schematic attached.
      Pictures provided by shopjimmy.
      • ivtec
        • Dec 2008
        • 1967
        Thanks dick_barton; BN44-00265B
        • ivtec
          • Dec 2008
          • 1967
          Thanks a bunch budm,apreciate.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you list your voltages as given on CN801 using pin number, name and voltage since you must have a voltage to light the red led.
            eg
            Pin 1, Power On/Off, xxx
            Pin 2, H_Sync, xxx
            Pin 3, STBY5.3, xxxx
            etc since it helps not to have to keep looking up the names on the schematic.
            The SM Q-50P04 is a P channel Mosfet. With your meter in diode mode you should be able to check the diode across the Drain - Source pin.
            • ivtec
              • Dec 2008
              • 1967
              Hi guys i have good news,i have a whole pile of electronic boards in a big box, it's so much stuff that i don't know what i have,as i was checking through the boards to check if i had a SM Mosfet, i was surprised and perplexed when i stumble on an exact same power supply for this tv also have the Main board and Tcon board,i must have picked these boards from a Samsung same tv broken screen,i even did not try to figure out the issue of the original power board just put in the one i had found and powered tv and tv came right up ,tv runs like a champ and have some spare parts,thanks
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                That was a stroke of luck.
                • howardc64
                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                  by howardc64
                  TV was fixed just after removing Samsung's rear snap cover.
                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                  Maybe PSU->backlight connector didn't have a good contact?...
                  07-23-2025, 12:34 AM
                  09-07-2024, 05:50 AM
                • C152Heavy
                  by C152Heavy
                  Summary for TL-DR readers:
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                • sansanpartida
                  Samsung QE82Q70RAT no backlight
                  by sansanpartida
                  Hi everyone!
                  Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                  My issue: No backlight.
                  Model: QE82Q70RAT
                  Type No: QE82Q70RAT
                  The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                  So hopefully, I can fix this cheaper.
                  05-22-2024, 06:56 AM
                • valvashon
                  Samsung UN60JU6500, stripe on left side of screen
                  by valvashon
                  Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
                  Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
                  Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
                  Thanks, Val
                  11-21-2025, 03:01 PM
