Telefunken te32843 b17
  • enricocite
    • Aug 2017
    • 10
    • arezzo
    Good morning, I have a TV with the problem that the audio feels but the video no, I understand the problem is the firmware. The TV has a 17mb60-4.1 card I wanted to know if it was the firmware to start the TV through usb
    Thanks so much
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Telefunken te32843 b17
    You have no image? Do you have backlights?
    • enricocite
      • Aug 2017
      • 10
      • arezzo
      yes i don't have a image but the backlights yes....
      • dskall
        • Oct 2016
        • 2905
        • usa
        Do you have voltage to the t-con?
        • enricocite
          • Aug 2017
          • 10
          • arezzo
          yess....
          • dskall
            • Oct 2016
            • 2905
            • usa
            I would try another t-con
            • enricocite
              • Aug 2017
              • 10
              • arezzo
              at the beginning i had only the red flashing led then i tried it with a firmware of the card but not the telefunken and something is improved in the way the leds turn on for this i would like to have a suitable firmware for this card
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
              • Tommes
                Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
                by Tommes
                Hey Folks,
                I'm searching for a Full Flash Recovery Software
                for my Telefunken D43F287N4CWII
                Mainboard Vestel 17MB110S
                Panel: VES430UNDB-2D-N12
                Productcode: 10119394
                Does anyone know, where I can get it ?
                Or is it possible, to extract it from a working mainboard ?
                The Support Telefunken/Vestel GER couldn't help me.
                The Vestel TR Support didn't answer my email.
                History:
                The main problem with my Telefunken D43F287N4CWII was,
                it just goes out after a while, sometimes after a...
                01-04-2022, 09:56 AM
