[OT] BGA soldering
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4540
    • Italy - Milan
    [OT] BGA soldering
    Hi, i was searching for some videos on Ytube on how factories make BGA soldering, but i havent found anything ("factory BGA soldering"), you know someone? Thanks..
    PS. Sorry for OT but it's relative to tv repairing...
  • RRice25541
    Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
    by RRice25541
    So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
    the color is all outa wack, like the settings have been corupted,
    I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
    so
    The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
    when i bring up the menu and type the pass codes to access either mode the menu disappears...
    05-13-2022, 10:44 PM
  • Glaval
    Sony OLED XBR-65A8G 4 flashes
    by Glaval
    Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
    01-23-2025, 04:04 PM
  • Ady2017
    SMD fuse soldering advice please
    by Ady2017
    Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
    11-07-2025, 12:03 PM
  • Azurain
    Elitebook 840 G5 Bios Chip Soldering Question
    by Azurain
    I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
    Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
    04-14-2023, 06:58 PM
  • masterm
    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
    by masterm
    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
    Problem with TV:
    - Netflix stopped working so i tried to do factory reset from the TV menu.
    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
    - After waiting for some time, the TV went into a boot loop.
    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
    04-30-2024, 03:03 AM
