Vestel 17mb61-2 I screwed up my TV
  • R_J
    • 9535
    Re: Vestel 17mb61-2 I screwed up my TV
    Have you tried adjusting it in the service menu? seems to have R,G,B, gain & offset adjustments
    • oldschoolgamer
      • Sep 2017
      • 49
      • Ireland
      #42
      Yeah but unfortunately for some reason you only get the choice to change EXT-1, VGA, and Ypbpr. I can kind of fix only them 3 inputs unless there's some other secret menu or something.
      • oldschoolgamer
        • Sep 2017
        • 49
        • Ireland
        #43
        I done what you said Tom and got a serial connection to the TV and got a boot dump. I'm using putty for Windows but I'm not sure how to get console access. I'm assuming if I do and I find the correct commands I might be able to correct the colour. You think this might be possible? I'm sorry for bothering you but when I learn myself I can help others instead of bothering them
        I got into the console now but I'm not too sure what to do from here. I need to try figure out
          Can you send me a copy of the firmware you are currently using?
            The console could be useful for editing files, but since your set is working it's probably not where we need to focus immediately.
            • oldschoolgamer
              • Sep 2017
              • 49
              • Ireland
              #46
              I have backed up all the files from the conf folder to a USB stick then copied them to the other board. I've tried a couple of firmwares and done the same thing but the hdmi channels just have a black screen. I also have the VESTEL_D1_PLUS_PNL.bin and panel.bin and another testtool_panel.bin. I can edit the colour gamma for temperatures in 2 of these files but since there's so many numbers I'm not entirely sure which I should change. If I'm editing one I need a bit less red gain and a lot less green gain. I'll get there anyway I might aswell get the other boards working afterwards and sell them on to someone else cheap that might need them.
              • oldschoolgamer
                • Sep 2017
                • 49
                • Ireland
                #47
                I'll make a one drive link and pm you the link to the files. I'll put my conf into a zip and send the closest working firmware I have (apart from the conf folder which I'm inserting afterwards.
                • oldschoolgamer
                  • Sep 2017
                  • 49
                  • Ireland
                  #48
                  I'll put up the files I used tomorrow. In the end it was the edid that was causing the hdmi problems and I was overlooking that. I got the edid from the other tv and renamed it to 37 instead of 42. Same with svn_revision_of_config.txt I changed it to 37 also just so the service menu says 37. I used Linux to flash the edid through hdmi but it kept reverting when the tv was restarted so I put it on a USB stick in spi/edid.edid and ran USB operations which flashed it and fixed the problem.
                  I still have the yellowish tint but I'm sure I can figure that out somehow in the panel files. I have the original TV's board fixed so that's one to sell on or 2 if I fix the other one also.
                  • oldschoolgamer
                    • Sep 2017
                    • 49
                    • Ireland
                    #49
                    I fixed the tint by changing the colour temp gain on my VESTEL_D1_Plus_PNL.bin file then deleting panel.bin so it would generate a new one. I had a new problem then with my horizon box. It was a HDCP error which stopped it from viewing the channel. I had to look that up and it's for copyright protection to prevent streaming. I actually flashed the edid and that still wouldn't fix it so I had to put the new board I bought back in and change the panel file on that instead to fix the colour.
                    Has anyone ever experienced that problem before on HDMI?
                    Apart from that I got the other board working and I know enough to help out others if they have firmware problems on a vestel.
                    • oldschoolgamer
                      • Sep 2017
                      • 49
                      • Ireland
                      #50
                      So I had to fix a HDCP error also but I now have 3 working 17MB61 main boards and only need one. It gives me more room to mess about with the TV's firmware and try make it look better.
                      Basically just posting to let people know I got it sorted and to sum it up quickly I originally started with a yellow tint. I tried to flash updated firmware thinking it would have RGB gain settings but I was wrong and ended up with a non functioning TV as I couldn't get the display working again properly. I then bricked the bootloader and ordered a new board then managed to brick that too but repaired them in the end by flashing the spi on both.
                      I got a working board for this tv and copied everything from the conf folder to my USB but basically just needed mb61_hwprofile.bin and mb61_swprofile.bin. Then I had to delete panel.bin from the conf folder because VESTEL_D1_PLUS_PNL.bin in the conf folder generates a new panel.bin file that works with your display. Also editing VESTEL_D1_PLUS_PNL.bin before generating the new panel file will get you the desired results if you have a display tint etc.
                      After all this I got a HDCP error with my set top box which I had to figure out about. Turns out if you put a file on the root of your USB stuck and just call it DownloadSpi.mb61 then run USB operations from the service menu you get your spi backed up including the edid and HDCP keys. I got them from the working board I have here then I put them in a folder on my USB stick called spi and ran USB operations again then rebooted. No more errors and everything works perfectly now on all boards. I even fixed the tint this all started over.
                      Hopefully someone finds this informative as it was impossible to find any information on any of these problems and I had to use trial and error to figure everything out. The serial connection and console (thanks to Tom66 for that info) was actually extremely helpful in both debugging and editing stuff. You can copy stuff to and from your USB with the console. If you just run USB operations even with a blank USB it will mount the USB to the directory /mnt/hd0a
                      Hopefully someone finds this extremely long post useful
                      • CuriousJohn
                        Ordained
                        • Dec 2018
                        • 134
                        • Great Britain
                        #51
                        Interesting and useful thanks
                        • حمدالله
                          • Oct 2018
                          • 5
                          • مصر
                          #52
                          17mb61-2 bios
                          • semih01sem
                            • Apr 2023
                            • Turkey
                            #53
                            Hi. How to edit vestel_d1_plus_pnl file? Which software?
                            • amine23
                              • Apr 2017
                              • 85
                              • Algeria
                              #54
                              hello every one i need dump bios of 17M61-2
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #55
                                try asking in this section of the forum hopefully you can find the rite firmware please let us know the tv make and model number and what lcd screen number is used
                                https://www.badcaps.net/forum/showthread.php?t=59877
                                • amine23
                                  • Apr 2017
                                  • 85
                                  • Algeria
                                  #56
                                  ok thank you
                                  • hamrani mouhsen
                                    • Jan 2025
                                    • Algerie
                                    #57
                                    Techwood vestel 17mb61-2 cl42RNY11p
                                    • Bazilwrc164
                                      Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                      by Bazilwrc164
                                      I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                      The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                      I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                      If anyone can provide:
                                      • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                      • Or a compatible EEPROM dump
                                      07-23-2025, 12:15 PM
                                    • massimomax
                                      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                      by massimomax
                                      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                      spero che qualcuno può averlo per riprogrammare eprom. grazie
                                      Post in English !!!
                                      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                      02-28-2025, 07:27 AM
                                    • anlu
                                      Vestel Firmware - Toshiba 32W133DN
                                      by anlu
                                      Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                                      Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                                      02-04-2023, 12:59 AM
                                    • piernov
                                      Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                                      by piernov
                                      Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                                      I suspect corrupt firmware but I haven't been able to find anything for this TV.
                                      TV model: Finlux 65-FUC-8060
                                      Mainboard: Vestel 17MB130S 23473048
                                      Panel: VES650QNTS-2D-U11
                                      At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                                      06-01-2024, 12:57 PM
                                    • TheUser
                                      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                      by TheUser
                                      Hello to everyone ,
                                      This is my first post here, and i would like to share with you a small story in case you can help me.
                                      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                      02-10-2024, 02:07 PM
