Sony KDL-42W829B - 'Error of panel ID' ?
  • RichL
    • Sep 2017
    I've just replaced the BAXL board on this TV after lightning close by caused it to fail and show three flashes of the red LED which (according to Sony's service manual) indicated that the BAXL board was the likely failed component.
    Have just replaced this and now getting another error, alternate flashing of green and amber LED's. According to the service manual this indicates 'Error of panel ID'. The manual gives no further details, can anyone shed any light on what this means and what the solution might be?
  • Hamie
    • Apr 2014
    • 1383
    Re: Sony KDL-42W829B - 'Error of panel ID' ?
    So you've replaced the mainbaord. Did you ensure it was a mainboard from the exact model?
    Sony also sometimes use LG and AUO panels for the same tv. Obviously if you have an AUO panel but install a mainbaord for an LG panel you'll get the amber and green code.
    • RichL
      • Sep 2017
      It was sold for the exact model number, and it is an exact match for part numbers as printed on the board itself - and there appear to be two versions available with one digit difference in a part number, so was sure to get this right. It looks visibly identical to the swapped out board.
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • AK_777
        Sony KD-65A1 Repair – 4 Red Blinks Error
        by AK_777
        Hi everyone!
        I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
        Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
        02-20-2025, 04:15 PM
      • Glaval
        Sony OLED XBR-65A8G 4 flashes
        by Glaval
        Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
        01-23-2025, 04:04 PM
      • r3vsEngIT
        Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
        by r3vsEngIT
        65x900h with the panel from a 65x930d.
        900H: model yr 2020, Samsung panel
        930D: model yr 2016, Innolux panel
        spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
        the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
        07-11-2023, 11:11 AM
      • guidodroid
        Bad Panel in Sony Bravia X850G
        by guidodroid
        Hello all,
        I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
        It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
        Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
        The issue is not as bad as others that I've seen around, but is indeed noticeable...
        03-19-2022, 12:08 PM
