Samsung LE40A756 video defect
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4462
    • Italy - Milan
    Hi, some days ago i've searched for an hour in to the forum without luck, i've used search terms like "streaks" "stripes" "lines", maybe due to my poor english i have miss other terms, the defect is as the pictures, When one first power up it shows no inteligible image but only vertical bars with some fading and moving as the video source (image 1), sometimes it shows like image 2-3, when one switches between video sources the images repair itself much and i can see like image 4-5. I have sprayed with freezer air the tcon and no change (also the little ISL gamma buffer chip) and the mainboard (but without desoldering the CPUs shield), my first doubt was CPU soldering, the mainboard also is keep bent in the back by a metallic sponge so is suspicious. Do you recognize this defect?
    Thanks.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung LE40A756 video defect
    Looks very much like a panel fault.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4462
      • Italy - Milan
      Switching it on shows always image 1, but if i detach left 2 ribbons from tcon to panel or right 2, the image shows up (half) but with vertical stripes from lighter items like images 4-5.
        Is the T-Con board mounted on the bottom center of the LCD panel?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4462
          • Italy - Milan
          No is the upper center.
          • dskall
            • Oct 2016
            • 2905
            • usa
            I would be looking at tab bonds. I have one with smearing on osd. Applied thermal pads on outer tabs and is working so far.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4462
              • Italy - Milan
              Maybe mine is different, i've watched 1 video on YTube of the EEVblog series (in the title "Samsung..dumpster dive") and tab bond don't affect, also a technician in an Italian forum with the same model same defect says: Tcon changed, tab bonds touched: no change, , ripple measured:OK.... If anyone remebers how to do a self test mode on the panel i thank he.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                The self test uses the tcon to test the panel so would only eliminate the mainboard if the picture was clear of faults and not the Tcon.
                Go to page 29 of the attached pdf
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Often touching the tab bonds does nothing, only when you strip the panel to reveal all of the tabs is it clear that part has come away from the screen.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    I've never successfully sorted out a panel that smears lines down the screen similar to the last photo in post #1, however I'm willing to learn.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4462
                      • Italy - Milan
                      OK thanks i will check the pdf, now i need a pause, too much tests today...
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4462
                        • Italy - Milan
                        The test for the LG seemed a bit unconfortable than the one i've done, i have at home another Samsung 46" lcd and i have tested the screen by connecting its power+mainboard, and the defect is the same.. so i think is the panel but is so strange that powering up the tv to the digital tv it shows only stripes, if i swap between inputs or i put in Analog TV the image come back (with little defect).. who knows why?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4462
                          • Italy - Milan
                          Hi i don't think anyone can help me but i say.. I have leaved the screen bezels and tested all the components (only resistors and ceramic caps) on the 2 boards on the top under the frame, nothing strange, i don't have test all the ultra tiny 100ohm resistors because i don't think them centers to the problem and i was not comfortable, then i have done the self tests for the FRC-tcon video output and the mainboard video out that are explained in the service manual, they played very well apart for a fixed big halo that involves some of the colors bars in the upper right area. Th next movement is to separate panel and foils to see if there is some substance inside, but on the top pcb nothing dirt apart a little dust.. BYE.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4462
                            • Italy - Milan
                            Some photos
                            http://bpssec.altervista.org/Samsung...6-difetto.html
                            i can notice that this halo is present in the test screens only when there are graphical elements in horizontal..
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4462
                              • Italy - Milan
                              I have tested the bigger testpoints on the side tabs of the screen, on each there was 6 bigger than others, but only 2 nudes, the top right tab previously i had noticed warmed a little more than the others (cools), on this and on the next two i have scracthed also the other 4 TP, on all TP (scratched and not) i have measured about 0,7v referred to chassis gnd. Is this normal? I was hoping for a broken trace but not.. are we sure tcon is good? If i don't fix the fault i want to sell all the boards..so..
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4462
                                • Italy - Milan
                                E-ehm, i apologize for my poor english :-G....
                                on the panel's pcb's i have tested all the testpoints, the tensions are repeated near all the tab bonds, apart from two TPs near the rightmost tab bond, one is lower than the others , 0,3v against approx 1v, the very last TP is Vcom34 (as i remember) and it measures 8,7v against 6,3v of all others Vcom TPs, is this a problem? The vcom voltages comes out from 3 buffer chips i7814hs on the tcon, i have changed two of them with 2 i7514hs that i had , usually theese chips are on the wide pcb's on the panel, anyway no changes... bye..
                                  09-07-2024, 05:50 AM
                                • alro7779
                                  Samsung UN55MU6103F video problem; has colored stripes on the display
                                  by alro7779
                                  Hello, everyone!
                                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                  09-27-2025, 11:29 PM
                                • shlomim412
                                  samsung ua55es6800 - no image
                                  by shlomim412
                                  hi
                                  having problem with samsung ua55es6800
                                  tv had backlight on, sound working - responds to the remote control but no image.
                                  check tcon board - had 12v in but no other voltages present.
                                  when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                  when leaving only left side connected - again no voltages and no image.
                                  put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                  kept trying to block less pins on the left ribbon cable...
                                  05-15-2024, 05:00 AM
                                  09-06-2024, 11:40 PM
