Fluid 55 LED 8018758a no backlight
  • microvibe
    • Mar 2013
    • 275
    • canada
    Re: Fluid 55 LED 8018758a no backlight
    Is there any tests I can do without the power supply in the TV.
    • alro7779
      Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
      by alro7779
      Hello, guys!
      I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
      Alex....
      10-03-2025, 05:49 PM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • Comp_Pro
      No Backlight Macbook A1990 820-01041
      by Comp_Pro
      Hello all,
      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
      Tests performed:
      There is no backlight even with a good screen.
      Backlight IC is receiving the correct support voltages.
      Fuse F8400 ok
      Current sense resistor R8400 ok
      Backlight IC is receiving 3.3V on enable pin.
      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
      Backlight IC receiving 5V from PP5V_G3S
      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
      05-06-2024, 10:23 PM
    • flashcoder
      Westinghouse DWM40F1G1 backlight blinks and turns off
      by flashcoder
      I got this TV (Westinghouse DWM40F1G1) that did not came on one day, blinked for a split second and turned off. I looked at it closer with flashlight and figured that the TV actually works, its just the backlight that does not.
      There is one PCB board - all of the components are on it: TP.MS3393.P85
      I took my oscilloscope and looked what is coming to the MOSFET that is switching current to LEDs - I could see that the PWM signal comes in but it cuts off almost instantly. I thought its the driver chip OB3350CP and so I replaced it.
      After that the...
      11-16-2021, 02:12 AM
