Panasonic viera txp50vt30e
  • onurka
    • Feb 2015
    • 17
    • Europa
    Hi everybody
    I need your helps.
    My children put 220 vac to coaxial sattalete input on the tv.😭
    After main fuse open to house.
    There aren't red blinking on the tv.
    Green led on.But screen is dark!
    What can I do?
    Regards
    By Onur
  • mostachio
    Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
    by mostachio
    Hi Badcaps,
    I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
    TV Details:
    Model # - TH-65DX700Z
    Symptoms:
    The television turns on and displays a picture then makes a clicking sound and turns off.
    I haven't opened it up yet but...
    09-04-2024, 02:32 AM
  • Ama Chur
    Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
    by Ama Chur
    After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
    02-21-2025, 08:12 PM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • badcappo
    Dead Panasonic Viera TX-P65STW50 Plasma TV
    by badcappo
    Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
    Diode type G972s6 - D101 with a short
    Mosfet 06N90E - Q301 shorted
    Fuse T5AH 250V - F103 blown
    Diode D301 shorted
    Relay DG1U-17VDC II - RL001 blown
    I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
    11-24-2024, 11:27 AM
  • J8rda7
    Panasonic Viera TX-L50E6E - no image
    by J8rda7
    the TV has a black screen. Sound OK, backlight OK.
    When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
    I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
    Thanks to anyone who can guide me in solving the problem.. and be patient with my english 🙂😁
    05-13-2024, 11:04 PM
