LG 42LB6500 wierd screen patterns
  • maleksa
    • Jul 2017
    • 50
    • Malaysia
    My LG 42LB6500 TV is showing some wierd patterns on the screen. I've attached a picture of the screen below.
    Could it be a cracked screen or something else? Any help/pointers is truly appreciated.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42LB6500 wierd screen patterns
    Clean and re-seat the T-CON Bd. cables to the Panel and from the Main Bd.
    • R_J
      • 9588
      It's either a cracked lcd panel or someone cleaned the screen with something and the liquid got onto the board that connects the panel to the t-con, Bet the t-con is at the bottom of the screen on this model
      • CDRW
        • Aug 2017
        • 5
        • Ukraine
        Are there any such replacement displays on sale? And how much the price will be.
          Definitely a cracked screen, not worth fixing as replacement panel usually costs the same as a new TV if not more.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • spice_disc
            Vizio TV M50-C1 reboot cycle and static on screen
            by spice_disc
            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
            09-08-2024, 02:37 PM
          • ipatch
            ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
            by ipatch
            i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
            08-24-2024, 02:36 PM
