Samsung 50" plasma PN50B650S1FXSA
  • jyoo
    • Mar 2015
    • United states
    I have a TV where the relay on the power board repeatedly clicks on and off when AC power cord plugged into outlet. I need the main board connected to the power board to see if the low voltage (3.3 or 5V) to the relay is constant. With all other boards disconnected and with the main board (BN94-02855F) connected to power supply board, the relay constantly clicks on and off. I inspected all other boards and no signs of bulging capacitor issues on any of the boards. There is another forum for the Samsung 50" plasma PN50A550 where they identified a tantalum capacitor C102 on the main board that fixed many clicking on and off TVs but have not come across anything online regarding a fix for this model. The main board on this model is different for the PN50A550 main board. Anyone out there with similar issue? Any information appreciated. Thank you!
  • maxvalutech
    • Dec 2014
    • 804
    • australia
    Re: Samsung 50" plasma PN50B650S1FXSA
    A 2009 model and when all boards except main disconnected but still clicking then PSU or main problem. Connect all boards except main and force PSU on and note if all power outputs come on line including Vs and Va. Also what is control board led showing.
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • Lee M.
      Samsung UN75RU8000FXZA bad main board?
      by Lee M.
      When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
      11-08-2023, 07:46 PM
    • dokma
      Samsung 50" plasma PS50Q97 with a dead main board
      by dokma
      Hello forum!
      This is my fourth post so I will try to start on the right foot by doing it properly right off the bat. I bought this plasma faulty to play around with. The main board is completely burnt. When I unplug everything but the power supply and the main board and I plug in the power chord I get plenty of smoke from the main board.
      Now, the model of the TV is a bit of a detective work. I couldn't find the model of the TV anywhere on the back cover or inside so I deduced it from the main board codes. SO I THINK this is PS50Q97.
      Now, since the board is...
      07-05-2020, 07:52 AM
