Panasonic TC-P50UT50 No Picture, Have Sound (No blinks)
  • GermanPlumber
    • Jun 2006
    • 11
    So I just recently received a broken Panasonic TC-P50UT50.
    TV turns on fine (I receive a status light when on, and status light turns off when i manually shut it down) with remote as well a physical buttons. I also get sound from the HDMI input.
    The issue I am having is I get no picture. No glow, nothing.
    I normally would say a bad SC board or a bad buffer board, but I normally have blinks to go on. This has no blinks.
    Per Tom66's post,
    If you have sound: This is often a Y-sustain fault. There is usually at least one fuse on the Y-sustain. First, unplug the TV and give it 5 minutes to discharge the capacitors. Then, set your DMM to the 200 ohm range. Touch the red and black together. Note the reading, it should be around 0-2 ohms. Now, touch one probe on one end of the fuse, and the other probe on the other end. If your DMM reads "1" on the left hand side, or "OL", the fuse is blown. If you get the same value as when you touched the probes together, the fuse is not blown.
    You should replace the fuse. Should that then blow again, you need to repair or replace the Y-sustain. Diagnosing a particular fault is tricky and requires considerable experience. Unless the Y-sustain is very expensive, or difficult to repair, I would advise a simple swap of the board.
    So I am leaning on the SC board being my culprit at I get a OL reading in Ohms on the fuses I tested on the SC board. Does anyone have a second opinion? I guess I'm concerned about the no blinks, and I'm worried I'll need to replace the SU and SD buffers as well, and I don't want to fry a good SC board.
  • GermanPlumber
    • Jun 2006
    • 11
    Re: Panasonic TC-P50UT50 No Picture, Have Sound (No blinks)
    EDIT: I just ordered all 3 to be safe. I update with my findings when they come in.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      OL is good , its a fuse! It has to be open , not closed.
      I think the post from Tom is related to a samsung plasma and not Panasonic.
      A defective SC board or other board on almost EVERY PANASONIC will result in a blinking pattern because the tv can not complete the test cycle of all boards when it turns on! It detects a error and shuts down.
      My personal feeling , and i am almost 100% sure , is you got a tv with a bad mainboard. ( bad BGA solder under GPU chip ).
      When the GPU is failing it usually wont result in a blinking pattern but just picture failing. ( stripes/weird colours etc ). You also got sound so the tv is actually working! ( It completed all test cycles from every board ).
      I dont think you got a bad sc/ss board and definately not a bad SU/SD board.
      I hope the boards were cheap , you can always save them as a spare.
      • GermanPlumber
        • Jun 2006
        • 11
        That is great to hear. Is there something I can do to verify a bad main before I order one? Thanks for the quick response.
        • GermanPlumber
          • Jun 2006
          • 11
          Well, I'm an idiot. I guess the previous owner took it upon himself to disconnect ribbons around the main and ss board. Once I reconnected everything I get 8 blinks. I'm doing my research now to hopefully diagnose this. Per Panasonic service repair guide, it can be ss, a, then panel.
          EDIT:Just performed the ss33 connector, tv turns on fine with no blinks. Check continuity on pins 1 and 2 for all 4 connectors from ss to panel. Turned the ss board over and it looks like someone deepfried the back of this thing. Thanks again for getting my wheels turning. I'm purchasing oleg's ebay service and sending it off. I'll post with an update if it resolved to help the next guy.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Haha , well you could have said that a bit earlier haha! Happened to me also.
            It is a common problem on this board , I think 1 or 2 FETS that are shorted. I would not send it off for repair but order a new one. Especially when someone tried to bake it....
            • tw2005
              • Oct 2011
              • 6458
              ? OL on my meter = open, open cct fuse = blown fuse
              What fuse we talking about on the SC? I did not even realise they had one.
              I would have guessed suspect main but sounds like you'll be on track with a SS repair.
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                SS board repair for that model is:
                1 DG302 & 1 RF2001
                They sell a kit on ebay for $12 that comes with a smd resistor that I have never had to use. A kit for $14 has all this plus an ic driver chip.
                • GermanPlumber
                  • Jun 2006
                  • 11
                  Just to help the next guy, it was a bad SS board. Used Oleg on ebay.
                  • kca
                    Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                    by kca
                    Hello all ~
                    I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                    This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                    No picture. No sound.
                    I tested all the voltages coming out of the power supply...
                    10-12-2023, 05:23 PM
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                    11-20-2024, 08:52 PM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • mar1in
                    Panasonic TH-55AS670A no picture no sound
                    by mar1in
                    I've got this Panasonic TV here with the following symptoms:
                    * Standby Light is solid RED
                    * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
                    * After a couple of seconds, LED is solid GREEN and without picture or sound.
                    I've tried a couple of things before tearing it apart:
                    * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
                    * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
                    09-10-2023, 11:10 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
