sony 40v2000 av problem
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Hi, i have sony 40v2000 AV 5 has sound but no piture component orders working, any help on how to fix it?
    Hispeck
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: sony 40v2000 av problem
    Are the backlights working?
    • hispeck
      • Aug 2015
      • 258
      • nigeria
      yes, everything is working only the AV 3 is not , when i put it on AV 3 i hear sound but no video
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • crackedprint
        Sony HCD-HX80R Amplifier Volume Control Problem
        by crackedprint
        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
        I have tried a Cold Reset as per the service manual.
        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
        I have looked all the way through the service manual and tried many online...
        01-21-2025, 12:18 PM
      • retrorepair
        SONY KDL-40P3600 Picture Problem
        by retrorepair
        Hello gurus, hope you can assist me...
        I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
        I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
        Thanks in advance.
        10-11-2024, 05:12 PM
      • guruji
        Sony mbx-266 problem
        by guruji
        Hello
        I this Sony mbx-266 it powers
        on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
        07-25-2025, 08:10 AM
      • YasaCh
        sony kd-49xf9005 4 red blinking problem
        by YasaCh
        Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
        05-05-2025, 08:40 AM
