hi......this my first thread.....so here goes..Only little knowledge in this field, just basic..thanks. MODEL. FSP 204-2F02...can't find much info for this...Its from a bush lcd32tv07hd....i've only been given the supply,to test......from a friend.he says it blew the inverter,I would like to know the value of two resistors ,because they are showing one 00.7 ohms and the other same.Theres two power out puts..12v.. giving 12.11v and 24v..no output......the one marked O/F on the 12v side,gettting upto 7v.............assuming this is standby...I am thinking it as two supplys......12v for main board and 24v for the inverter. i can get a replacement board if need be.......[may be wrong]..you guys will know......cheers, and sorry for long post............sorry forgot to mention, he said the tv screen would flash on and off......
bush power supply v07-w04
Re: bush power supply v07-w04
The switched 24VDC will not be present until you give the pull-up Voltage on the O/F pin, you can simulate to ON command by using a 1~2K resistor between the O/F pin and the 12V pin.
If the 24VDC is still not present using the resistor, then you need to see if you do have PFC Boosted Voltage of 380~400VDC between the two legs of the main filter cap or not.Last edited by budm; 07-26-2017, 01:43 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
hello..the pin marked O/F..I can not get a actual reading on this pin, the voltage is not stable..plus can you tell the ohms rating of those two resistors.....my reading is in and out of circuit, are 00.7 ohms..the rest read as normal....thanxComment
So you need to find out hwy the main board is not sending the O/F command to turn on the power supply board. Nothing wrong with those very low Ohms resistors any way.
R67 is 0.47 Ohms.
R17 I cannot tell the color, picture is not focused.
Do not forget to subtract your meter probe resistances from the readings to get the value of the resistor.Last edited by budm; 07-26-2017, 07:10 PM.Never stop learning
thanx again 4 reply....resistor R17 green.gold.orange.yellow.silver.......my pal now states the inverter board has a blown a 0HMS resister near one of the transformers.and made a small crater and burn mark....hope this helps...thank you.Comment
what inverter board is used in this tv have you got a picture of it as we may of seen this fault before so can advise you of more tests etcComment
not sure what postage cost is but at this price cant really go wrong
http://appliancespareparts.mysimples...d-buy-now-onlyComment
hi......vinceroger69...and others......thank you , ordered it price= £4.99 plus £3.99 post....cheaper than flea bay £18.00......see how long it takes.....Ive now got tv at home....found 3 caps on main board high esr..waiting for replacement parts.....
cheers all........Comment
update..put new second hand, inverter board in..tv fires up....backlights on..but no picture on screen...so i plugged it into freeveiw box..still blank screen...remote seems to work..until you press the power off button on remote,the remote stops working,so you have to unplug from mains,power on ,back to normal..but still no picture.......getting 12v,24v,stby 3v.could it be firmware issue, because before this, it was booting up normal, but only for a second............cheers for any feedback.......Comment
Have you got a supply voltage on the Tcon board. Look for the smd fuse and check voltage.Willing to help but I'm no expert.Comment
0.3mv or 0.3 ohms each way? Measure with your probe on one side of the fuse and chassis and then measure the other side of the fuse and chassis.Last edited by dick_barton; 08-03-2017, 08:43 AM.Willing to help but I'm no expert.Comment
Sorry but I find your reply a little confusing.
Turn the tv off.
Set your meter to ohms and place your probes on each side of the fuse.
If the fuse is good it should show close to 0.0 ohms.
If it's blown then it will show xx Kohms or OL
Then if the fuse is not blown put your meter on DC volts and black probe on chassis and red probe on one side of the fuse to see what voltage the Tcon runs at.Last edited by dick_barton; 08-03-2017, 09:13 AM.Willing to help but I'm no expert.Comment
OK so your Tcon fuse is fine but you have no voltage there which would explain why you have no picture.
Can you post clear well focused pictures of your mainbaord.Last edited by dick_barton; 08-03-2017, 10:08 AM.Willing to help but I'm no expert.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by CMCMHello Everybody,
Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
The outputs marked 12v and 20v are all measuring only 1v.
The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
The capacitors physically look clean (no bludgesor leaks) and... - Loading...
