Re: KDL-60W600B won't open just Red Blinks 6 times
i got it, Thanks, will test it & post results,
Thanks alot.
D6803 is a dual diode common Cathode. Put the meter probe between the middle pin (Cathode) and either one of the two outer pins (the two outer pins are connected together, they are Anode).Leave a comment:
Noted, Thanks budm, will post results here accordingly, BTW i need to check D6803 with meter set on ohm & diode mode, i can test it while put each probe of the meter on D6803 right? since D6803 have 3 legs, sorry noobi questions, hope you don't mind,
Thanks.Last edited by Ali101; 08-02-2017, 11:01 PM.Leave a comment:
You need to test that diode to see if it has low resistance reading in both directions or not. So TV unplug and set meter to Ohm mode, also test it in diode mode too. If that diode is bad you will not get boosted Voltage.Leave a comment:
Yes i checked D6803 and it have 89.6V and after tv turn on it goes down slow slow to 0.00V, do i need to check T6501 as well? If yes than how to check thisLeave a comment:
So did you check the diode D6803 that TOMM66 pointed out to see if it is OK or not?Leave a comment:
Dear budm, thanks alot,
On CN6401 Pin 6 to 8 have 12.6V and after tv turn on it goes to 0.00v i check CAP C6401and it 12.6V and it goes to 0.00V after tv turn on,
Your further help will be highly appreciated,
@tom many thanks bro,
@budm once again thank you very much.Leave a comment:
Please also check the DCV between the two legs of the filter cap C6401 to see if the Voltage goes up and then goes back down or not.Leave a comment:
It's worth checking that D6803 isn't shorted, it's the diode for the boost converter part of the board. I've seen these diodes fail before and they cause various faults, usually low boost output voltage.Leave a comment:
OMG, budm, this is simply genesis work,
since my board is little different so i check it to put red probe on below picture yellow mark & reading it give me is 89.5 V or sometime 88V on both (CAP C6801 & CAP C6802) and once TV turn on it goes down & stay on 25V to 30V, i set my Multi meter on 200 DC range,
so does it means i need to replace these both (CAP C6801 & CAP C6802) or i should buy other PSU?
your all help is highly appreciated, since i almost gave up from my tv but you give it a big Hope, God bless you bro,
Thanks.
BTW, check the REG 12V pin on the connector CN6401 to see if it goes up to 12V and then drops down or not.Last edited by budm; 08-02-2017, 09:26 AM.Leave a comment:
Thanks.Leave a comment:
LCD panel model "ND4S600DNX0101".
No luck finding the spec. sheet.
LED strips (16) 2014SONY 60A PLU1 3228 08 REV1.1
http://www.usefulparts.com/tv-parts/...ny-kdl-60w630b
http://www.ebay.com/itm/Sony-KDL-60W...item4b14aa7854
So it has 4 strings of LEDs, each string has 4 LEDs strips connected in series, each strip has 8 LEDs, so the total LEDs for one string is 8 LEDs x 4 strips = 32 LEDs, so if each LED has Vf of 3V that means the total Vf for each string is 32 LEDs x 3V = 96V, so the output of the boost converter should be at least 96V + Vdrops for the PWM Controlled MOSFET (there are four of them: Q6802~6805) which I estimate to be around 15~20V range so the output of the booster should be over 100V.
Power supply/led DRIVER BOARD APS-374 (CH).Sony 1-474-586-12 GL2 PS
Pictures provided by shojimmy.
So if the DCV reading on the capacitor C6801 shows 90V then we know that Voltage booster is not working.
You can check the Voltage of the CAP C6801 on the top side of the board by putting the Black probe of the meter on the middle leg of D6801, and the red probe on the middle leg of D6082.Last edited by budm; 08-02-2017, 12:34 AM.Leave a comment:
BTW, please also look at the LCD panel for the model number of the LCD panel then we may be able to find the specification sheets that may tell us how many LEDs are used in the panel and what the Voltage requirement is for the LED's.Leave a comment:
Thanks budm really appreciated your help, atm i am on work so not able to give results but once i reached home, will check Cap C6801 and post results here,
One again thank you very much, May God Bless you.Leave a comment:
I have a feeling that your LED's are OK, but the booster circuit is not working, I expect to see more than 90VDC but not 100%sure since we do not have that much details information about this TV.Leave a comment:
Dear budm, sorry my bad, since i am very nervous due to it might LCD penal fault so recognized C6801 Cap as CN6801, please accept my sincere apology, will check & get back to you with results,
ThanksLeave a comment:
Thanks for help budm, appreciated your kind assistance,
so i have to open LCD panel to check whether some led got bad? from all above tests/board readings seems like my LED panel have issue right?
Not sure if filter cap is attached image, if so than below is reading i take while tv power on, but if filter cap is different than below image than your help will be appreciated to find & test further more,
Thanks.
CN6801:
Pin 1=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
Pin 2=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
Pin 3=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
Pin 4=90 V, after turn tv on it drop slowly 89...88..87......3.2.1
CN6802:
Pin 1=13.5 V, after turn tv on it drop slowly 12...11..10......3.2.1
Pin 2=13.7 V, after turn tv on it drop slowly 12...11..10......3.2.1
Pin 3=13.6 V, after turn tv on it drop slowly 12...11..10......3.2.1
Pin 4=13.6 V, after turn tv on it drop slowly 12...11..10......3.2.1
Pin 5=0.00 V,
https://www.badcaps.net/forum/attach...1&d=1501157949Last edited by budm; 08-01-2017, 10:22 PM.Leave a comment:
You can get LED tester, something similar to this:
http://www.ebay.com/itm/0-300V-SID-G...item1c740cd5ab
Thanks.
CN6801:
CN6802:
Pin 5=0.00 V,Last edited by Ali101; 08-01-2017, 09:50 PM.Leave a comment:
by htv239Hello,
I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by SamungggI've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if... -
by mecha1166I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
- Loading...
