Service Menu And NAND Flash KFG1GN6W2D For Samsung TV UE32D6100.
  • daviddrf
    • Jul 2017
    • 5
    • Spain
    Hello all. First of all, sorry for my bad English. I'm trying to improve it everyday.
    It seems my UE32D6100 Samsung TV got bricked when I tried to downgrade it through Samygo's DNS server as you can see here:
    https://forum.samygo.tv/viewtopic.ph...rt=270#p100850
    I tried to reset the EEPROM but it didn't worked. I made an Ex-Link cable for diagnosis and it shows the following output:
    Code:
    > S 0067 onboot(May 17 2011-16:18:53)
    GenoaS with Parma, GenoaS only
    So it seems that my flash NAND KFG1GN6W2D were the partitions are stored should be reprogrammed or replaced instead of replacing all the entire BN94-05514F mainboard. Anyone knows where could I find that flash NAND KFG1GN6W2D reprogrammed for my TV please?
    The other question is I need the service menu configuration for my TV because it was lost when I reseted the EEPROM. I should need someone's similar model screencaps of the service menu like this ones:
    https://wiki.samygo.tv/index.php?tit..._Version_No_09
    Could anyone help me please? Thanks in advance .
  • OCBSlimz
    • Nov 2017
    • 16
    • France
    Re: Service Menu And NAND Flash KFG1GN6W2D For Samsung TV UE32D6100.
    Hi
    I know this dates back a bit but did you find a solution for this ?
    I have the same problem ...
    Matt
    • daviddrf
      • Jul 2017
      • 5
      • Spain
      Originally posted by OCBSlimz
      Hi
      Matt
      Hello. Did you brick your mainboard too?
      • OCBSlimz
        • Nov 2017
        • 16
        • France
        I have a reboot cycle, after a bad update.
        Was looking for a dump of the OneNand chip..
        • daviddrf
          • Jul 2017
          • 5
          • Spain
          Aha, I'm sorry about that. How did you get in that reboot cycle?
          • dutn
            • Apr 2015
            • 6
            • Nederland
            I see that this topic is a bit old, but I have exactly the same problem as described here. The tv is in a reboot loop (D5720) after a bad update. Is there a solution to reprogram the OneNAND chip without desoldering it?
            • daviddrf
              • Jul 2017
              • 5
              • Spain
              Hello, I hope you will be able to solve that. I had to replace the mainboard. Godbye and good luck.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4541
                • Italy - Milan
                Hello, what do you mean for "bad update"? Wbat happened?
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • Deeloc
                  How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                  by Deeloc
                  I have a 1tb WALRAM SSD (Photo)
                  Controller SM2259XT2G (photo)
                  Samsung memory (photo):
                  Part Number K9DVGB8J1B DCK0
                  Name V-NAND V6
                  Type TLC
                  The SSD itself is detected as 1gb, but is not initialized.
                  There is a Sata to USB adapter
                  A lot of SMI MPTool, did not flash it. compare flash fail (17)
                  K9DVGB8J1B is not listed anywhere
                  What to flash?​...
                  06-05-2024, 08:32 AM
                • DoOm86
                  Swap nand flash smartphone for data recovery
                  by DoOm86
                  Hello everyone.
                  I would like to know more about the following topic:
                  Nand flash on smartphone for data recovery.
                  I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                  But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                  How does it works? How do I know if data are encrypted or where is the key?
                  I know there are also very expensive external socket where you can put the nand flash in...
                  08-20-2023, 07:10 AM
                • ekozeko333
                  [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                  by ekozeko333
                  I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                  🔥 The Problem Started After Suspected ESD/PD Fault
                  I experienced a power issue or ESD event through a USB-C charger
                  After that, the NX20P5090 power switch was visibly burned and was replaced
                  Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                  🧠 What I’ve Done So Far
                  Flashed...
                  06-21-2025, 02:48 AM
                • corrize
                  Nikon D800 camera - flash don’t work and capacitor don’t charge
                  by corrize
                  Hello, I'm stuck in troubleshooting…
                  The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                  In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                  When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                  10-01-2022, 10:02 AM
