Kogan KALED463D1A - horizontal lines on screen
  • NickFi
    • Nov 2015
    • 7
    My parents' 46 inch Kogan LCD started showing horizontal lines on screen. They show up in all modes (TV, HDMI input, AV Input), with or without signal applied.
    Depending on the image white content, the lines are more or less visible but I could not improve the image by adjusting the brightness or contrast. I also did a factory reset of the tv, but that did not fix the problem.
    I opened the TV and did a visual inspection (everything looks good). I also measured the electrolytic capacitors from power supply using a ESR meter and they seem to be in excellent condition (the TV is just over 4 years old). The display is Samsung LTA460HQ12 and the T-Con board is model Samsung SD120PBMB4C6LV0.0.
    Based on what I read on forums, I would suspect either a bad contact on the ribbon cables of the T-Con board, or the T-Con board itself or the LCD panel. I am concerned that some people said that most of the time horizontal lines are caused by the panel and not T-Con board. When I get there, I'll open it again and clean the ribbon contacts. I'm am not sure if it's worth ordering the T-Con board.
    Maybe some people may recognize the nature of the fault from the photos I provided and offer some advice.
    Thanks,
    Nick
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Kogan KALED463D1A - horizontal lines on screen
    disconnect one side of the t-con at a time power the set up and see if the half that is connected shows a good picture or not, then do the other half.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • NickFi
      • Nov 2015
      • 7
      Thanks for the idea, I will try it and report back.
      • tw2005
        • Oct 2011
        • 6458
        4 years, you've done well. I'm going to suggest panel
        https://www.badcaps.net/forum/showth...ighlight=kogan
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • kdaniel
          Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
          by kdaniel
          As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
          There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
          After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
          Left...
          11-16-2022, 09:23 AM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • theo321
          Horizontal black lines on screen - please for your help
          by theo321
          Hello Everyone
          I need your help to repair my poor Samsung TV which decided not to let me watch my favorites series in the afternoon. Suddenly black horizontal lines appeared on the screen making my life a hell
          Photo:
          https://ibb.co/Kyhm9M5
          Close up photo:
          https://ibb.co/zNtv4XP
          I have seen many youtube videos with guys who put a tape in ribbon cable and TV fixed in a magic way (I have tried without success).
          My TV model is: LE46C750R2W
          Photo:
          https://ibb.co/Q6RFN94
          I have tried to disconnect one...
          06-19-2023, 04:28 AM
