Samsung un65es8000
  • nelson6861
    • Jul 2016
    • 67
    Samsung un65es8000
    Once tv is turned on. You see samsung logo and it fades to back.
    Backlights are on and Audio is heard.
    I am thinking its t-con board. So do i search for 12v on t-con board
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Samsung un65es8000
    disconnect one side of the ribbon cables that goes from t-con to the panel and see if you get a pic, then replace and do the same for the other half.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • dskall
      • Oct 2016
      • 2905
      • usa
      You should have fuse on t-con you can check for voltage on each side
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
