Proscan led tv no picture
  • osmaidy
    • Oct 2014
    Greetings,
    I have a ProScan LED TV, model PLDED5030A-B-RK and it has sound but no picture. I figured the LED driver board probably needs replacement but when I purchased a replacement from ebay, it did not work. I am getting 24 volts to the driver board from the power supply board but that is about all I can tshoot.
    Is this the proper logic or is it possible the LED strip is defective? I suppose it is possible somebody sold me a defective driver board but not sure if I should try to sink any more money into this set. The voltages on the power supply board are reading properly like at the ribbon cable connectors.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Proscan led tv no picture
    Do you see image on screen with flashlight? Do you see a flash on screen when you first power on? You have no backlights correct?
    • osmaidy
      • Oct 2014
      No image on screen with flash light that I could tell. The screen comes up with the ProScan splash screen when I power it up but then it goes to black screen right away.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        If you have an image on the screen when you first switch on then you need to check the voltages at the led connector at switch on. They may rise quickly but just as quick fall to a lower value.
        It could also be that the mainboard is turning the leds off but without any voltage readings there's no way to tell.
        Some picture of your boards would be helpful and also the voltages on the power supply low voltage connectors.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Most likely LED backlight strings have shorted LEDs. So the backlight will come on and then the Driver will sense overcurrent and shut down power to the Backlights.
          • osmaidy
            • Oct 2014
            I did check all the voltages on the main power supply board and they were all valid readings like for 5 V and 12 V and whatever other voltages were labeled on the connectors.
            I also had 24 V getting to the LED driver board. I checked that right at the connector on the power supply board heading to the LED driver board so voltages are stable.
            I suppose this means I have bad LED strips.
              The Boosted Voltage for the LED will be a lot higher than the 24VDC, but since we do not have the pictures of your board so we do not know exactly what you have in your TV.
              http://www.shopjimmy.com/catalogsear.../?q=PLDED5030A
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                It's the connector connected to the Leds themselves which is located on the led driver board that you need to check the voltages on.
                Can you supply photo's of your boards
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Hink85
                  Samsung UN65RU8000FXZA Led Driver Board
                  by Hink85
                  Hi All,
                  I picked up a Samsung UN65RU8000FXZA 4k Smart TV a few weeks ago, in hopes I could repair it and get it working. It was purchased in Nov 2019, Samsung already replaced this tv by the original purchaser.
                  I have eliminated the main board and power supply, and back lights are working. It was cycling on and off when i got it, I disconnected ribbon cables until I pinpointed it down to an LED driver board, and with the suspect board or ribbon cable section, 3/4 of the TV will now stay on and it no longer cycles on and off. I haven't found any shorted capacitors...
                  08-12-2020, 07:03 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • howardc64
                  QN75QN85BAFXZA no backlight
                  by howardc64
                  2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
                  PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
                  07-03-2025, 05:08 PM
