Samsung UN60EH6050 No Picture/Flickering Backlight
  • philtvman
    • Jun 2016
    • 94
    • America
    TV will turn on fine, but there is no picture and the backlights flicker constantly. If I unplug the LVDS between he T-Con and main board, the backlights stop flickering (there just is of course no picture). I really thought it was the T-Con, so I sent it off to be repaired. The guy who repaired it said he tested it on a model in his shop and it worked. However, I'm having the same issue before and after the 'repair'.
    These are my voltages with the T-Con unplugged from the main board:
    1: B13V...12.6
    2: PWM_DIM...2.9
    3: B13V...12.6
    4: B13V...12.6
    5: Vamp...12.6
    6: BLU_ON/OFF...4.9
    7: Vamp...12.6
    8: GND...0
    9: GND...0
    10: GND...0
    11: B5V...5.3
    12: A5V...5.3
    13: B5V...5.3
    14: POWER ON/OFF...3.5
    These are my voltages with the all boards plugged in:
    1: B13V...12.6
    2: PWM_DIM...jumps constantly from 0-2.2
    3: B13V...12.6
    4: B13V...12.6
    5: Vamp...12.6
    6: BLU_ON/OFF...4.9
    7: Vamp...12.6
    8: GND...0
    9: GND...0
    10: GND...0
    11: B5V...5.3
    12: A5V...5.3
    13: B5V...5.3
    So as far as I could tell, the only thing that differs between plugging the T-Con into the main board is that PWM_DIM goes crazy which would explain the back lights flickering.
    Would this point to a main board fault or a power board fault. I'm hoping it's not the T-Con at this point. The guy that worked on it said he is 100% sure it works, based on his reviews I'd like to believe him.
  • philtvman
    • Jun 2016
    • 94
    • America
    Re: Samsung UN60EH6050 No Picture/Flickering Backlight
    Boards
    • dskall
      • Oct 2016
      • 2905
      • usa
      Have you checked to make sure it is not just bad connection in cable?
      • philtvman
        • Jun 2016
        • 94
        • America
        Yes I've checked, all seem good.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I believe that backlight flickering can be caused when there is a led fault (failing led) but not always. Turn down your backlights and see if the flickering reduces with a reduction in led drive.
          • philtvman
            • Jun 2016
            • 94
            • America
            I have no picture at all, so I'm unable to turn them down at the moment. If an LED was failing causing the flicker, wouldn't that make them always flicker? They only do with the main/t-con connected. Thanks for the help, I appreciate it.
            • dskall
              • Oct 2016
              • 2905
              • usa
              You do have voltage at your t-con?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Can you disconnect the leds and use a flashlight to see if you have an image on the screen.
                • philtvman
                  • Jun 2016
                  • 94
                  • America
                  Getting 12.4V to the T-Con.
                  Disconnected the LEDs, but still no picture. PWM_DIM also still jumps from 1.6V-1.9V give or take. The TV takes about 10 seconds or so to start flickering, before that the backlight is constant (just no picture). PWM_DIM stays at 1.98V during this time, then starts jumping around after that.
                  • philtvman
                    • Jun 2016
                    • 94
                    • America
                    Did note that I am getting no response from the remote. Even with just the main and power board hooked up, I can't turn the unit off. Would this be indicative of a faulty main?
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Well my guess would have been t-con. So next I guess would be main board.
                        If the fixer guy sure that the T-CON is good then you should see the image on the screen even with flickering backlights since flickering lights will not cause not to have image on the screen, so at this point I lean toward main board.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          +1
                          There is a video about these tcons. One of the chips going faulty.
                          https://www.youtube.com/watch?v=ahPsylZvues
                          • philtvman
                            • Jun 2016
                            • 94
                            • America
                            Just hooked up the new main board and all is good now, thanks everybody!
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Thanks for feedback
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Glad you got it sorted.
                                  09-07-2024, 05:50 AM
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • JJAAMM
                                  by JJAAMM
                                  Problem
                                  07-06-2023, 06:01 AM
                                • Mgiffune
                                  by Mgiffune
                                  06-09-2024, 10:28 AM
                                • Dodgethis
                                  Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                  by Dodgethis
                                  Hello all,
                                  This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                  09-11-2024, 07:39 AM
