Defective chip on ribbon cables
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Defective chip on ribbon cables
    clean and reseat the corresponding cable that relates to that part of the panel.
    don't power the set on without the heat sink on, or else quick panel death will happen.
    since it was not there in your first pics, hopefully that is all that needs to be done.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Lloyd6202
      • May 2017
      • 59
      Shes back from the dead boys its a beautiful site. Was a loose ribbon cable that was causing the vertical line...its been a great project was about to give up instead the knowled ive gathered from this forum is priceless. Deffinetly owe it to u all..so total cost was $306.00 and rebuilt to last a couple more years...
      • Lloyd6202
        • May 2017
        • 59
        Now on to my samsung 58 inch ive started a thread already
        https://www.badcaps.net/forum/showthread.php?t=62970
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • Pize92
          Defective BIOS chip
          by Pize92
          Hello everyone.
          I have a problem.
          The BIOS chip on my Lenovo Legion 5 17ACH6H appears to be defective. I wanted to read the chip first with the ch431a programmer and then with the t48 and create a dump. However, it always threw an error during verification.
          I then bought a new BIOS chip from Aliexpress and loaded an existing dump onto the chip. With the corresponding DMI.
          Unfortunately, the laptop now keeps restarting.
          My question is, can you simply use the DMI from a foreign dump, or is the motherboard completely lost due to the defective BIOS chip?
          08-19-2025, 10:59 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
          by SMDFlea
          Bad...
          09-02-2021, 04:40 PM
