Defective chip on ribbon cables
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Defective chip on ribbon cables
    clean and reseat the corresponding cable that relates to that part of the panel.
    don't power the set on without the heat sink on, or else quick panel death will happen.
    since it was not there in your first pics, hopefully that is all that needs to be done.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Lloyd6202
      • May 2017
      • 59
      Shes back from the dead boys its a beautiful site. Was a loose ribbon cable that was causing the vertical line...its been a great project was about to give up instead the knowled ive gathered from this forum is priceless. Deffinetly owe it to u all..so total cost was $306.00 and rebuilt to last a couple more years...
      • Lloyd6202
        • May 2017
        • 59
        Now on to my samsung 58 inch ive started a thread already
        https://www.badcaps.net/forum/showthread.php?t=62970
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
          by SMDFlea
          Bad...
          09-02-2021, 04:40 PM
        • rumpumpel1
          How do I find a defective RAM chip
          by rumpumpel1
          I have a ThinkPad T14 which always finds an error at a very specific address during a RAM test. I therefore believe that exactly one of the RAM chips on the mainboard is defective. How do I find this defective RAM chip?
          Today, 11:55 AM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
