Samsung UN40F6400 standby LED blink wont turn ON
  • mugunthans
    • Dec 2016
    • 32
    Its time to get expert help to fix my TV as its almost dead !!!
    Its Samsung UN40F6400 and power board BN44-00622D
    The problem is - When power up the TV - standby LED blink twice for 5 Times and relay click but not ON and cycle continue...
    Based on advise from other thread on this forum and tested the below.
    1. Disconnected Main board cable 20Pins (CNM803)
    > LED backlight ON for half of the screen and half of screen flicker. Tear down the LCD panel and diffuser, found only top 3 Strip light UP and bottom 4 strips (2x2) flicker. So, removed the top 3 and swapped with bottom 4 LEDs but still top 3 is UP good and bottom same flicker.
    Hope the LED strips are found to be good - Please concure.
    2. Voltage measurement without Main board and LED panel connection
    Power supply @ CNM803
    OD On/Off - 3v
    B13V - 13v
    B5v - 5v
    DIM1,2,3,4 - 3V
    A5V- 5v
    BLU on/off - 5v
    Power On/off - 3v
    LED Driver - Legend
    Ch 1-60v
    Ch 2,34 - 120v
    with/without LED
    CM851/CNM852 - 46v/67v
    CNM853 - 17v/35v
    Booster reading
    Measurement without LED panel connection
    Ch 1 - 70V (c9106)
    Ch 2,3,4 - 150v (c9206/c9306/c9406)
    Measurement with LED connection
    Ch 1 - 44V (c9106)
    Ch 2,3,4 - 85v (c9206/c9306/c9406)
    HOT Caps reading (with/without LED)
    CP810S - 305v / 396V
    CP814S - 305v / 396Vc
    anyone has schematics of BN44-0622D ?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UN40F6400 standby LED blink wont turn ON
    You swapped 3 strips for 4. Did you swap forth strip?
    • mugunthans
      • Dec 2016
      • 32
      Yes, 4/5 - swapped with 1/2 and 6/7 swapped with 1/2 - same effect (1/2/3 constant light UP and rest flicker)- Hope LED strips should have no issue.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Have you checked your connection between your strips and panel connector?
        • Hamie
          • Apr 2014
          • 1383
          http://www.ohmsupplies.co.uk/epages/...8&Locale=en_AU
          • mugunthans
            • Dec 2016
            • 32
            [SOLVED] Re: Samsung UN40F6400 standby LED blink wont turn ON
            I got some local expert advise..which is to replace SMD resister RS802 (10R0 - 10 Ohms) and Youtube channel also confirmed the same.
            https://www.youtube.com/watch?v=nEzBdUTpe24&t=567s
            but I could not source SMD...so I replaced it with normal Quarter watt resister...and Its working
            Thank you very much for your valuable time and advise.
              "HOT Caps reading (with/without LED)
              CP814S - 305v / 396Vc"
              Something is not making sense since that resistor is for supplying the Voltage to run the PFC IC and your PFC Boosted Voltage is 396VDC as it should be, so I cannot see the relationship between one strip of LED is not working properly and that 10 Ohms resistor in the PFC circuit.
              Or you are indicating that with LED connector in place and the one of the LED strip is not on you are getting 305VDc? I would expect that ALL LED strips will be affected wit 305VDC reading on the main filter cap and it also does not make sense to have 305VDC on the main filter cap when your AC line Voltage is 230VAC and the low Voltage shutdown should have kicked in too.
              BTW, what is resistance reading of that BAD 10 Ohms resistor?
              • mugunthans
                • Dec 2016
                • 32
                Not all the LED 7 strips failed...
                First 3 is working constant full bright.
                Next 2 flicker like flash and try to glow slowly and next 2 setup start flicker try to glow full bright and goes off last 4 dtrip...Same cycle repeat.
                I have attached the photo in my previous post.
                The resistor reading is (80ohms).
                In fact i was waiting for your advice from my first post..
                Special thanks to you...
                • mugunthans
                  • Dec 2016
                  • 32
                  My Apologies...Its 580Ω
                    09-07-2024, 05:50 AM
                  • fixit007
                    Samsung flicker - BN44-00932T board or else?
                    by fixit007
                    I picked up this TV that the prior owner said - just died.
                    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                    05-04-2024, 06:14 PM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                  • Kaar3l
                    Samsung QLED QE65Q7FNAT only standby light
                    by Kaar3l
                    TV: Samsung QLED QE65Q7FNAT
                    PSU: BN4400940A
                    MB: BN94-12832K
                    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                    09-24-2024, 01:35 PM
