Panasonic VIERA TC-L32X5 - One LED blink
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Panasonic VIERA TC-L32X5 - One LED blink
    Additional photo?
    404. That’s an error.
    The requested URL was not found on this server. That’s all we know.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      With your meter across the two legs of the capacitor C7806, what voltage do you have when you first switch on. It may just spike and then drop just as quickly.
      46V sounds awful low when the capacitor is rated at 160V so I would expect around 120V DC.
      What voltage is at TP7501 (D7507)?
      How many leds are in each strip. I believe they are 6V leds so should give a better idea of what the voltage should be. (6V x Number of leds in the strip)
      • WannaTheater
        • Jun 2017
        • 18
        Link fixed- The additional photos are showing the two LED strips, and the one that goes *almost* completely dark after all the LEDs flash on really bright.
        It looks like each strip has about 36 LEDs.
        C7806 starts at 46VDC, then jumps up to 135V, where is stays until the TV shuts itself off.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          135V at the leds would appear to be correct. If they were connected as one strip of 36 leds x 3V = 108V which is more than enough to keep the leds on.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you post pictures of the power supply board especially the area around the led circuitry top and bottom. Nice and sharp so you can see the connections and components
            • WannaTheater
              • Jun 2017
              • 18
              Done.. The best I could do. There are no visible discolorations, puffy/leaking/smelling like fish caps, etc with the exception of diode D7306 (The legs are pretty tarnished).
              I even brought tout the headgear magnifiers to check for burns/discolorations.
              • BookWormStud
                • Aug 2017
                • 17
                • India
                #27
                So your problem was on which board ?
                • WannaTheater
                  • Jun 2017
                  • 18
                  Never figured it out. Discarded.
                  • BookWormStud
                    • Aug 2017
                    • 17
                    • India
                    #29
                    Is there anyway to jump the wires and turn on the Backlights with Main/A-Board disconnected from P-Board?
                    • rustytierod
                      • Sep 2014
                      • 81
                      Will not turn on, I get a red status light, no blinks except one briefly if I press power again. No picture.
                      • howardc64
                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                        by howardc64
                        • Prior owner tried a replacement main board. No difference.
                        • Samsung 2x red blinking standby LED = panel fault
                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                        07-19-2025, 10:54 PM
                      • Vebririon
                        panasonic TX-P50V10E 6 blink led problem
                        by Vebririon
                        I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                        Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                        I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                        05-17-2025, 10:16 AM
                      • Jacksoft
                        Panasonic Viera TX-P46G10E 11 blink even after fan replacement
                        by Jacksoft
                        I have here a Plasma TV TX-P46G10E that before had a problem where it had issues with 11 blinks (FAN SOS) BEFORE starting normally. After that it works for all day long.
                        It had some bad cold solder and I remade them all. After I replaced a fan that was half-dead (no RMP signal from the respective pin, but ok with 9V).
                        Now the TV power up instantly and works perfect... only without the backplate!
                        If the backplate is placed on the TV shutsdown after about 10min and start blinking with the 11 blinks. If I shutdown and re-powerup it starts blinking after a bunch of...
                        11-26-2023, 07:22 AM
                      • cloo
                        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                        by cloo
                        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                        After doing a factory reset this problem was gone and the picture was back to...
                        01-06-2025, 06:02 AM
                      • howardc64
                        LG 49UJ6500 LCD panel lighter band that goes away
                        by howardc64
                        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                        02-19-2023, 12:13 AM
