LG 37LC7D Bad/Bulging Caps
  • MvZiC MaN
    • Apr 2017
    • 19
    Apologies if this isnt the correct place for this. This is my first real post here.
    Found myself an LG 37" at the curb today. Did some testing and found it didnt like to turn on all the time.
    Pulled it apart and found 4 or 5 bad Capacitors and im assuming thats the only issue.
    When it doesn't turn on, the green power light flashes 2 or 3 times then flashes red once and repeats. My main question is has anyone come across one of these sets with the same issue? and am i wrong in assuming capacitors are Polarized?
    Heres a few pictures of the Power board. The Bulging/Bad caps as far as i can tell are located at C202,C206,C210 and C217
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LG 37LC7D Bad/Bulging Caps
    I would replace all of the caps apart from the really big mains filter.
    The white side of the caps with the - indicates the negative side. As you can see they line up with a mark on the PCB.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I think everyone who repairs electronics has come across bad caps
      • MvZiC MaN
        • Apr 2017
        • 19
        I plan on replacing them all eventually but id like to replace the individual ones first to Confirm that they are the whole issue..
        How Should i go about locating Individual Capacitors?
        is Ebay a safe place to buy them or do you all have a better source?
        C202,C206 and C217 are all the same parts. (10v 2200uf V0A PET)
        and C210 (35v 1500uf V4A PET)
        Edit: I found these, are they the ones i need?
        http://www.ebay.com/itm/2pcs-1500uf-...EAAOSw-4BXafFc
        and
        http://www.ebay.com/itm/5pcs-2200uF-...1%26rkt%3D1%26
        • diif
          • Feb 2014
          • 6978
          • England
          I suggest Digikey or Mouser as there are lots of fakes and junk caps on ebay. I use Panasonic FR FM and FC series. Low ESR and good quality.
          I've learnt to never assume, especially when it comes to electronics but considering the visual deformity of those caps and the fact there is power, it's a fair guess to say replacing them should get the TV powering on again.
          • dskall
            • Oct 2016
            • 2905
            • usa
            You need low esr for these power supplies. The first link was low esr caps the second was for general purpose and not suitable for smps
            • MvZiC MaN
              • Apr 2017
              • 19
              i have several old Computer power supplies laying around and some other old electronics. Im wondering if i can salvage some caps from them for testing purposes until i can order the whole set of caps for my power board.
              • MvZiC MaN
                • Apr 2017
                • 19
                Looking on Digikey and im all kinds of Confused! lol Im new to trying to fix tvs and locate these tiny parts. This is only my 2nd tv ive tried to repair.
                How about these ones?
                http://www.ebay.com/itm/4x-Nichicon-...rvJfbpZYjBrKVA
                • culcuhain
                  • May 2016
                  • 186
                  • U$@
                  Caps are cheap. Order new. Do it once and do it right.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    What to look for on power supply caps is low esr, 105c temp, equal or real close capacity uf rating and equal or higher voltage rating
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      +1 All of us who repair would not think twice of first replacing all the bulged capacitors irrespective of any other faults which may be found afterwards.
                      You cannot test the speed of the car if the engine is not running. So get the power supply up and running before worrying about any other possible fault. Capacitors are cheap.
                      • neilc6
                        • Nov 2015
                        • 1550
                        I have repaired two of these models. One had C202, C206, C210 and C217 bulged and the other had C202, C217 and C221 replaced with wrong values (assuming they were bulged initially). I would recommend replacement of all the following capacitors.
                        C202, C206, C217, C218 - 2200uF/10V
                        C208 - 2200uF/25V
                        C210 - 1500uF/35V (one tv this value was 1000uF/35V and bulged)
                        C221 - 470uF/10V (can use 35V to simplify ordering)
                        C222 - 470uF/25V (can use 35V to simplify ordering)
                        C226 - 470uF/35V
                        If you order from Digikey, if you limit the search to Rubycon caps, in stock, bulk or cut tape, there will be less options.
                        • re-atari
                          Denon AVR-X2000 mainboard caps bulging
                          by re-atari
                          I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
                          I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
                          09-23-2020, 10:37 AM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
                        • Foetuss
                          Gigabyte GA-6OXT :: caps question
                          by Foetuss
                          Good evening
                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                          But I was also suprised about the bigger boys, which are 330µF 25V.
                          Could it be they used 25V caps because they were cheaper / available at that time?...
                          02-11-2025, 12:22 PM
