Help: LG 55LM8600 Stuck on Boot Up LG Logo Screen
  • NYSLC93
    • Jun 2017
    Hello –
    N00b here…
    I have a 5 year old LG 55” LED LCD TV (55LM8600) which recently froze up on me while watching TV thru my HD antenna. In any event, the screen froze so I turned the TV off, and when I turned the TV back on, the TV would freeze on the LG start up logo.
    First, I unplugged the TV and let it sit. Nothing.
    Second, I tried every conceivable method to hard reset the TV. Nothing.
    Third, I removed the main board and baked it @ 385-degrees for 10-minutes. Nothing. Still gets stuck on the LG start up screen.
    Fourth, I removed the main board and baked it @400-degrees for 15-minutes. – Now there's no LG logo on start up – just a black screen. Fried the board I guess.
    Fifth, I ordered a used replacement board from ebay, installed it, and when I turned on the tv, I got the LG logo, then it cycled off to a blank screen. It only did that one time. I re-installed, re-set, un-plugged the TV, now it goes back to the LG logo.
    Sixth, I downloaded the firmware update (Dec 2016) to a USB drive, and tried updating per the manufacturers directions. Nothing. Still stuck on the start-up screen.
    I'm at a loss. Is there anything else I should check before returning this replacement board??
    Thanks!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Help: LG 55LM8600 Stuck on Boot Up LG Logo Screen
    Try unplugging wifi if it has one. Known to cause problems for whatever reason
    • NYSLC93
      • Jun 2017
      Thanks, but Not sure I follow.
      Unplug the WiFi in the house?
      The TV won't even get past the boot up logo, so I'm not sure it's even connecting to WiFi.
      • dskall
        • Oct 2016
        • 2905
        • usa
        If it is internet capable it has a module probably at bottom of set. It will have a mac address on module. Again for unknown reasons it can keep tv from coming on
        • culcuhain
          • May 2016
          • 186
          • U$@
          Stop baking your boards.
          • NYSLC93
            • Jun 2017
            Got it. I'll try unplugging my WiFi, however I live in an apt building so it's free to pick up others.
            Any other suggestions?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Need good clear straight on pictures of back of tv with cover off and each board.
